Tracking PRI Usage via SNMP on a 3925 Voice Gateway
dtran
Level 6
Level 6
Hi all,
I've got a 3925 router with 5 PRI's I am trying to set up MRTG to track the PRI usage for trending report. I believe I've the correct SNMP OID and I am able pull the correct data I am looking for from SNMP walk but for some reason the data return is only on the PRI's in slot0. I do not see any data return for the PRI's in slot1 and slot2.
The 3925 is running IOS 15.4.2T and I am using this OID cpmDS1ActiveDS0s. Has anyone run into this issue ?
Thanks in advance !!
Danny
Chris Lee
This report is built from CUCM CDR but can show you your individual AND/OR combined PRI utilization going thru your GW (can do SIP trunks too). This Utilization reporting can be On-Demand or emailed to you on a scheduled basis:
cmatrasko
Hello, this is a great question.
Is there anyway I can do this via SNMP through an OID?
Thanks!
Cheryl
