Transaltion pattern query
singh-ashok
I have query :
What does a TP of X! configured on CUCM 7x acheive ?
Following conditions apply :
Calling Party Transformations
Required Field
Required Field
Connected Party Transformations
Required Field
Required Field
Called Party Transformations
Thing is this TP is the only dependency for a Partition & a CSS. The CSS / Partition has no other TP / RP associated with it. So curious to know about the behavior of this TP.
Trying tobeone
Here you have not mentioned to what number its translated. Normally this is done so that any number entered between 1 and 32 digits will not be forwarded or matched to any other patterns, so that no wrongly dialled number will be matched or forwarded.
Anyway its not a mandatory configuration and depends on your environment and configuration.
HTH..Please rate helpful posts and if you gets the solution, please post it so that it will be useful for others....
Rgds
TT
