Transcoding between SIP trunk and SIP Endpoint on CME
edwardforgacs
Is it possible to get CME to transcode between a SIP endpoint and SIP trunk? If so, it seems virtually impossible to get it to actually invoke the transcoder even when there is a codec mismatch.
We know the transcoder works because it gets invoked e.g. for hold music on G.722 SCCP calls.
This is the nightmare scenario which we cannot get to work:
1. SCCP phone places a call to SIP trunk. The SIP trunk supports G.711a only so the call uses this codec.
2. SCCP phone initiates a transfer to a SIP phone. Both the SCCP and SIP phones support G.722 so the transfer call starts as G.722.
3. Transfer is completed but the SIP phone gets no audio. Watching Wireshark traces CME is trying to send G.722 packets to the SIP trunk which doesn't support them, and it is sending back 488 Not acceptable here errors.
When using a consultative instead of blind transfer at step 2, the transcoder does get invoked and it works, i.e. the SIP phone has audio. With a blind transfer (press Transfer button a second time on SCCP phone before answering on SIP phone), the SIP phone has no audio and no attempt is made to transcode.
6 Replies 6
Gaurav Purohit
Hello Edward,
I believe as long as the Media resources are properly configured (to support desired codecs) and registered, CME is going to invoke it.
Can you provide the configs? Is G.722 configured to be supported? what is the coded negotiated when performing consultative transfer on both the legs of transcoder?
In the consultative transfer scenario, G.722 gets negotiated, so CME must be transcoding the SIP trunk from G.711 to G.722.
Here are the bits of the config I think are relevant? It is a very long and complex config.
dspfarm profile 2 transcode
codec g722-64
codec g711ulaw
codec g711alaw
maximum sessions 7
associate application SCCP
dspfarm profile 1 conference
codec g711alaw
codec g711ulaw
codec g722-64
maximum conference-participants 16
maximum sessions 1
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 4
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 2
sdspfarm tag 1 conference
sdspfarm tag 2 transcode
sdspfarm tag 3 mtp
conference hardware
dial-peer voice 600 voip
description SIP Trunk
destination-pattern 6[5-9].
media flow-around
media forking
redirect ip2ip
rtp payload-type comfort-noise 13
session protocol sipv2
session target ipv4:192.168.100.5
session transport tcp
incoming called-number 650
incoming uri from SERVER05
voice-class sip profiles 1
dtmf-relay rtp-nte
playout-delay nominal 100
playout-delay mode fixed
codec g711alaw
no vad
supplementary-service h450.12
no supplementary-service sip refer
voice register dn  15
number 115
allow watch
pickup-group 550
name Cordless
no-reg
label Cordless
mwi
voice register pool  15
id mac 0874.7102.8296
number 1 dn 15
cor incoming CallSIPOutgoing default
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username 115 password *****
no vad
voice service voip
sip
  rel1xx disable
  header-passing
  referto-passing
  registrar server expires max 3600 min 300
  localhost dns:domain.com.au
  asymmetric payload full
  early-offer forced
  midcall-signaling passthru
  pass-thru headers unsupp
  pass-thru content unsupp
  no call service stop
ericdolton
Just a thought but you may want to try not including G.722 in the voice class codec command in the voice register pool so the phones will use G711 instead of G.722.
For example
voice class codec 99
 codec preference 1 g711alaw
 codec preference 2 g711ulaw bytes 80
 codec preference 3 g723ar53
 codec preference 4 g723ar63 bytes 144
 codec preference 5 g723r53
 codec preference 6 g723r63 bytes 120
id mac 0030.94C2.A22A
voice-class codec 99
We want to use G.722 for internal calls though.
can you run the debug dspfarm all and debug sccp messages output?
Unfortunately not much success with those debugs. I tried debug sccp messages and it didn't seem to generate any output at all which was very strange. Debug dspfarm all is not available on the 2901 running IOS 15.1.
Quite a lot of output from debug ccsip errors however there are errors being generated even in the successful calls. Is there anything useful here or anything that stands out? The IP media forking errors look like they could be related?
000392: Dec  8 13:23:11.430: //3367/3182657D8FC3/SIP/Error/act_dying_new_message:
Received unexpected response, dropping it
000393: Dec  8 13:23:12.442: %SKINNYMAIN-4-KEYPADFAST: Keypad messages from the phone 1 are too fast
000394: Dec  8 13:23:12.442: %SKINNYMAIN-4-KEYPADFAST: Keypad messages from the phone 1 are too fast
000395: Dec  8 13:23:12.642: //3374/4009900B8FCB/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer:
MF: Unable to read data from TD Container..
000396: Dec  8 13:23:12.642: //3374/4009900B8FCB/SIP/Error/ccsip_ipip_media_forking_forked_leg_config:
MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
000397: Dec  8 13:23:12.646: //3374/4009900B8FCB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
MF: Not a Forked SIP leg..
000398: Dec  8 13:23:12.646: //3374/4009900B8FCB/SIP/Error/sipSPI_ipip_build_consolidated_header_list:
No headers associated with passthrulist tag: 0 and copylist tag: 0
SIP: (3374) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: Attribute mid, level 1 instance 1 not found.
SIP: Attribute mid, level 2 instance 1 not found.
000399: Dec  8 13:23:13.130: //3374/4009900B8FCB/SIP/Error/sipSPIDoVideoNegotiation:
Destination port is zero in media line 2
000400: Dec  8 13:23:15.082: //3374/4009900B8FCB/SIP/Error/is_sip_snr_call:
CCSIP: invalid call entry
000401: Dec  8 13:23:15.082: //3374/4009900B8FCB/SIP/Error/is_sip_snr_call:
000402: Dec  8 13:23:15.450: //3367/3182657D8FC3/SIP/Error/act_dying_new_message:
000403: Dec  8 13:23:17.686: //3379/419BC13F8FD1/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer:
000404: Dec  8 13:23:17.686: //3379/419BC13F8FD1/SIP/Error/ccsip_ipip_media_forking_forked_leg_config:
000405: Dec  8 13:23:17.690: //3379/419BC13F8FD1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
000406: Dec  8 13:23:17.690: //3379/419BC13F8FD1/SIP/Error/sipSPI_ipip_build_consolidated_header_list:
SIP: (3379) Group (a= group line) attribute, level 65535 instance 1 not found.
000407: Dec  8 13:23:19.042: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_call_service_msg:
This is not sip line side, unable to update the callinfo ui parameters
000408: Dec  8 13:23:19.046: //3379/419BC13F8FD1/SIP/Error/sipSPIPreProcessCallerIDMediaEvent:
Don't expect a callerid update in STATE_RECD_PROCEEDING
000409: Dec  8 13:23:19.046: //3379/419BC13F8FD1/SIP/Error/sact_app_media_event_send_request:
Cannot send UPDATE without calling ccsip_api_update_allowed
000410: Dec  8 13:23:19.470: //3367/3182657D8FC3/SIP/Error/act_dying_new_message:
000411: Dec  8 13:23:21.853: //-1/xxxxxxxxxxxx/SIP/Error/sipsdp_src_dest_create:
SRC SDP already there use old SRC SDP
000412: Dec  8 13:23:21.853: //3374/4009900B8FCB/SIP/Error/sipSPIOutgoingCallSDP:
  owner_sessionid is already their OR src_sdp is corrupted
000413: Dec  8 13:23:21.865: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_call_service_msg:
000414: Dec  8 13:23:22.061: //3374/4009900B8FCB/SIP/Error/sipSPI_ipip_GetPassthruContent:
Content-Type: Not present in SIP Message
000415: Dec  8 13:23:22.061: //3379/419BC13F8FD1/SIP/Error/sipSPI_ipip_restore_sdp_context:
Invalid CCB/sdp ctxt ptr
000416: Dec  8 13:23:22.061: //3374/4009900B8FCB/SIP/Error/sipSPIUpdateRtpSession:
voip_rtp_update_callinfo returns FALSE
000417: Dec  8 13:23:22.061: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIUpdateDynamicPayloadinuse:
Dynamic payload 8 - not in dynamic range[96-127] Group (a= group line) attribute, level 65535 instance 1 not found.
000418: Dec  8 13:23:22.061: //-1/xxxxxxxxxxxx/SIP/Error/sipsdp_src_dest_create:
SRC SDP already there use old SRC SDP Group (a= group line) attribute, level 65535 instance 1 not found.
000419: Dec  8 13:23:22.061: //3374/4009900B8FCB/SIP/Error/sipSPIOutgoingCallSDP:
000420: Dec  8 13:23:22.065: //3379/419BC13F8FD1/SIP/Error/act_handle_app_media_event:
Ignoring RESPONSE_ANSWER
000421: Dec  8 13:23:22.073: //3374/4009900B8FCB/SIP/Error/sipSPI_ipip_GetPassthruContent:
000422: Dec  8 13:23:22.073: //3379/419BC13F8FD1/SIP/Error/sipSPI_ipip_restore_sdp_context:
000423: Dec  8 13:23:22.073: //3374/4009900B8FCB/SIP/Error/sipSPIUpdateRtpSession:
000424: Dec  8 13:23:22.073: //3379/419BC13F8FD1/SIP/Error/act_handle_app_media_event:
000425: Dec  8 13:23:22.481: //3379/419BC13F8FD1/SIP/Error/sact_recd_success_new_message_response:
Unexpected response
