03-14-2019 01:16 PM
Dears,
i have two very easy questions,
Solved! Go to Solution.
03-15-2019 01:10 AM
1) There are various programs for audio recording. I would strogly suggest Audacity which is commonly used for cases like yours (record/edit/change codec/download).
2)Yes this is possible. Depending on your device, you may use key-expansion module with up to 36/72 speed dials (with employess extensions)
G
03-15-2019 01:10 AM
G
