voice register dial inbound help
davec4351
Hi Folks,
I have an issue with my incoming sip phones. However, outgoing works on the sip. On my skinny phones outgoing and incoming work both ways. When i do a show dial-peer voice summary I see the 40004 and 40003 dial-peers, however those dial peers do not ring when inbound calls are made. I have been going crazy over this for the last few days trying to debug and get it work! Any help would be greatly appreciated!
ICNISR4k#show dial-peer voice su
ICNISR4k#show dial-peer voice summary
dial-peer hunt 0
AD PRE PASS SESS-SER-GRP\ OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE VRF
10 voip up up .T 0 syst dns:callcentric.com NA
21474- voip up up 1000$ 1 syst loopback:rtp NA
83647
11 voip up up 1[2-9]..[2-9]...- 0 syst dns:callcentric.com NA
20009 pots up up 1006$ 0 50/0/1 NA
20010 pots up up 1777291851$ 9 50/0/1 NA
20011 pots up up 1009$ 0 50/0/3 NA
20012 pots up up 1777291851$ 9 50/0/3 NA
40003 voip up up 1002$ 0 syst ipv4:192.168.1.250:5 NA
40004 voip up up 1003$ 0 syst ipv4:192.168.1.251:5 NA
6 voip up up 1... 0 syst ipv4:192.168.1.100 NA
For server-grp details please execute command:show voice class server-group <tag_id>
To see complete session target for ipv6 use 'sh running-config | section dial-peer <tag>
ICNISR4k#
#show voice register pool all brief
Pool ID IP Address Ln DN Number State
1 00C1.B1FD.2E5D 192.168.1.217 1 1 1010$ REGISTERED
2 00C1.B1FD.270B 192.168.1.218 1 2 1011$ REGISTERED
davec4351
Thanks to a cisco engineer, the resolution was
voice translation-profile incoming
translate calling 2
to
translate called 2
davec4351
translate calling 2
to
translate called 2
