Translate ANI of anonymous, unknown, or private
cpcrouter
I am working on a problem with CID tranlation.  I have the following translation rules in place.
voice translation-rule 5
rule 1 /^\+1\(.*\)/ /\1/
rule 2 /^\([0-9]\)\(.*\)/ /\1\2/
rule 3 /.........../ /1234567890/
rule 4 /........../ /1234567890/
rule 5 /........./ /1234567890/
rule 7 /^$/ /1234567890/
rule 8 /[^0-9]$/ /1234567890/
With this block I can successfully test it for 'anonymous' ,but it does not work for 'unknown' or 'private'.  Any ideas what I'm missing?
RouterA#test voice translation-rule 5 anonymous
Matched with rule 5
Original number: anonymous      Translated number: 1234567890
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
5 Replies 5
paolo bevilacqua
Are you using SIP? Then use SIP profiles, not translation-rules that are made for number, not strings.
We are using SIP outbound but PTSN inbound.
Try to add a rule to your translation rule
rule 9 /.*/ /1234567890/
Response Signature
/.*/ would match all numbers including null
I don't want to change legitamate inbound numbers just the ones that wont show (private/unknown).
cpcrouter
Actually it seems that if I add:
rule 7 /......./ /1234567890/
works, as there are 7 dots to match 'private' or 'unknown' or 'blocked'.
Now I just have to test it.
