Translate Calling number to be Unknown
Ossama OHK
Dears,
we need to translate the calling number of our Tele Marketing team to be unknown, kindly your support to fix this issue.
9 Replies 9
Hi Ossama
Can you please elaborate more your question.
Eg. CUCM or CUCME
Which version are you running
Carlo
Please rate all helpful posts "The more you help the more you learn"
Dear Carlo,
we need implement this on CUCM V.9.0.
Hi Ossama.
Please in my previous post, I suggested you a solution which is valid for all cucm version ;)
Cheers
Carlo
Hi Ossama,
I agree with Carlo on the CUCM solution. However, I prefer to implement this on the gateway so that you  avoid duplicate config in SRST gateway in case you are using it.
This is my recommendation but all ways should give the same result.
*** Please rate useful posts
Dear Carlo,
Thanks for your reply.
I did the above steps that you send but nothing change still the number appear on the mobile device.
Did you properly adjust the CSS as required???
java
if this helps, please rate
I suggest to configure the following on your outgoing dialpeer to PSTN.
voice translation-rule X
 rule 1 /^"enter your telemarketing number"/ //
voice translation-profile TRANSLATE-TELEMARKETING
 translate calling X
dial-peer voice 101 pots/voip
 translation-profile outgoing TRANSLATE-TELEMARKETING
**** please rate useful posts
Dear Mohamad,,
Thanks for your reply is there any way to configure in CUCM?
Hi Ossama.
On cumc configure a route patter to let Telemarketing agents to call out and put in in a new partition Eg. Out_Telemarketing.
On that Route Pattern modify "Calling Line Presentation ID" and "Calling Name Presentation" values to Restricted
Create a new CSS including that newly created partition and all other partition to let those users to call internally.
Assign this CSS to telemarketing users lines.
Carlo
