IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1213 Views
  • 6 replies
I have recently purchased a Cisco 7960G IP Phone. But when I connect the phone to my router an error comes up saying "Protocol Application Invalid" I have a Mac computer, so how do I fix this to use my phone? Thank You!
when I try to use pcd version 10.5.1 to discover the existing cucm cluster 8.6.1 , it times out with the following msg. CLI command timed out for node, IP_Add of CUCMunable to contact the specified cluster node. verify the hostname/IP address and cre...
Hi all , i have the following scenariolync extensions : 571x cucm extensionx : 7xxx Is it possible  to route the call to the pstn  from lync exension through cucm ,?If possible what are the  configuration required ? Thanks
susim by Participant
  • 113 Views
  • 2 replies
Hi All, Currently CUCM 10.5 is running in Esxi 4.1. Is it mandate to disable the LRO ( Because of the Esxi version ) or we can keep it ON.We are experiencing the SDL out of service between the nodes where all the nodes residing in same subnet & Esxi.
gpsriramdc by Enthusiast
  • 617 Views
  • 4 replies
Dear all,am using cme 9.1 with both sip and sccp phones. all things were fine for several months suddenly no outgoing nor incoming call are available and the stats of the dial-peer is down.attached is sh run and debug file when i try to press 9 to ca...
hi,Sip trunk is only for outbound calls ? for example if i have sip server  and i created sip trunk , the same sip trunk will be used for inbound calls from the sip server to the cucm ? Thanks
  • 144 Views
  • 2 replies
