06-17-2015 03:24 AM - edited 03-17-2019 03:22 AM
Dears,
we need to translate the calling number of our Tele Marketing team to be unknown, kindly your support to fix this issue.
06-17-2015 03:37 AM
Hi Ossama
Can you please elaborate more your question.
Eg. CUCM or CUCME
Which version are you running
Carlo
06-17-2015 06:00 AM
Dear Carlo,
we need implement this on CUCM V.9.0.
06-17-2015 06:06 AM
Hi Ossama.
Please in my previous post, I suggested you a solution which is valid for all cucm version ;)
Cheers
Carlo
06-17-2015 11:42 AM
Hi Ossama,
I agree with Carlo on the CUCM solution. However, I prefer to implement this on the gateway so that you avoid duplicate config in SRST gateway in case you are using it.
This is my recommendation but all ways should give the same result.
*** Please rate useful posts
06-18-2015 05:54 AM
Dear Carlo,
Thanks for your reply.
I did the above steps that you send but nothing change still the number appear on the mobile device.
06-18-2015 06:51 AM
Did you properly adjust the CSS as required???
06-17-2015 03:45 AM
I suggest to configure the following on your outgoing dialpeer to PSTN.
voice translation-rule X
rule 1 /^"enter your telemarketing number"/ //
voice translation-profile TRANSLATE-TELEMARKETING
translate calling X
dial-peer voice 101 pots/voip
translation-profile outgoing TRANSLATE-TELEMARKETING
**** please rate useful posts
06-17-2015 05:33 AM
Dear Mohamad,,
Thanks for your reply is there any way to configure in CUCM?
06-17-2015 05:48 AM
Hi Ossama.
On cumc configure a route patter to let Telemarketing agents to call out and put in in a new partition Eg. Out_Telemarketing.
On that Route Pattern modify "Calling Line Presentation ID" and "Calling Name Presentation" values to Restricted
Create a new CSS including that newly created partition and all other partition to let those users to call internally.
Assign this CSS to telemarketing users lines.
Carlo
