Translate the calling number
Janos.nagy
Hello I have a problem,
I want to translate the calling number on a sip-trunk.
Can anyone tell me the right "Incoming Calling Party Settings"
I want to remove all starting "0" and replace it with a "+"
Example:
I want to change the calling number from 00049305555555555 to +49305555555555
We are using the CUCM 8.0.3.20000-2
Thanks for your help
In that case you will need to use calling party xformation...
1. create a calling party xformation pattern....assing it to a valid partition
pattern: 000.49!
discard digit: predot
prefix: +
2. On the incoming calling party settings...Set the CSS that has access to the xformation pattern
define above
3. Uncheck use device pool css
NB: if you are using h323 gateway then you need to know what the number type your rpovider presents to you. Once you know this you can then apply the CSS to this number type. For sip you dont have this, so you do it only at one place
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Ayodeji Okanlawon
voice translation-rule 1
rule 1 /^000\(.+\)/ /+\1/
voice translation-profile PSTN-IN
translate calling 1
You then apply it to the relevant dial-peer in the inbound direction
dial-peer voice 99998 voip
translation-profile incoming PSTN-IN
Ohh I´m sorry.
I do not want to translate the calling number on a voice router. I want to translate the number on the CUCM Business.
pattern: 000.49!
prefix: +
define above
You are the men.
It works. I do not know about the Calling Party Transformation Patterns.
