09-28-2011 08:46 AM - edited 03-16-2019 07:13 AM
Hi Guys
I have the follow problem: I have a Translation Patterns in the CUCM and in the
If I put a DN, works fine.
Cristian
09-28-2011 09:29 AM
The Translation Pattern will have a CSS assigned to it. The Hunt Pilot must exist in a Partition included in the CSS chosen.
09-28-2011 12:09 PM
1.- The Translation Pattern have PT_Phone and CSS_PEK_LDI and
2.- Hunt Pilot is 1407 and have PT_Finanzas
3.- The extension into the LG have PT_Phone and CSS_PEK_LDI
4.- The CSS_PEK_LDI have PT_Phone and PT_Finanzas
5.- The CSS of GW have is CSS_PEK_LDI
Internal calls to Hunt Pilot works fine. External calls using the Translation Pattern not works.
TIA
Cristian
01-10-2017 02:27 AM
Hi Cristian,
Did you get this problem resolved ? I too have the same problem now.
Tried translation both in gateway and CUCM, but no luck.
01-10-2017 04:30 AM
Dear SwathyEdayath
Has been long time but I think to solved adding the partition in the CSS incoming, into the GW configuration.
01-10-2017 10:18 PM
Thank you. I too have resolved it some how..there was a translation present in gateway to different number which was overiding cucm configuration.
01-11-2017 04:18 AM
perfect..!!!! :)
