Translation profile / Dial peer for 10 DID numbers
Ahsan Hashmi
hi,
I need suggestion on how to go by. I have 10 DID  number from ITSP out of which 3 will by binded to  phones ie MD, Manager and reception phone, and around 30 phones in my office will be using remaning 7 DID for outbound call... Now how do i manage configure it in my cisco cube router?
CUCM >sip trunk> CUBE>sip trunk > ITSP
44-29-20003xxx    xxxx  xxxx
44-29-20004xxx    xxxx  xxxx
44-29-20006xxx    xxxx  xxxx
All these numbers have there username and password. On the sip-ua i can only authenticate 1 username and password for outgoing calls how can i do it for all the 10?
I think you are confusing DIDs with trunk ports.  DID is just a number that can be assigned to a phone DN or anything else i.e. hunt pilot.  If you assign multiple phones to the same DID you are crating shared line appearance where all of the phones would ring at the same time if the number is called.  With SIP trunk you are not restricted to number of DIDs like you are with lets say a POTS line, you can order as many DIDs as you want from the telco.  As to number of calls allowed (trunking) again with SIP trunk this is driven by number of sessions you purchase from the telco, so if you order 50 sessions with 100 DIDs you can have 50 concurrent in/out calls to/from the SIP trunk to any of the DIDs or single DID.
Chris
7 Replies 7
Chris Deren
I have never heard of telco requiring different authentication for each number, here is what this would typically be setup:
1. Configure CUBE for SIP trunk integration, add authentication config under sip-ua
2. For the users using DIDs configure them in CUCM (assuming you have CUCM) with the external phone number mapped to it
3. Configure the Route Patterns to have "use external phone number mask" checked, so that the DID can be passed to the CUBE
4. On CUBE simply use dial-peers to direct the call to the SIP trunk
HTH,
Chris
that part is understoond. But how to configure 30 IP phone to chosse betweeen 7 DIDs ? ( in first come first serve basis ) :S
somthing like hunt pilot or somthing of that sort?
Chris
Oh ok.. I get it now.. then I have to speak to my service provider. Because as of now, there is 1 session per number provide to me.
Thanks a lot chris, appreciate your help.
Ahsan
No problem, please rate all helpful posts!
Chris
Hi chris,,
I need your help again.
I am having trouble with landing calls to CUCM i believe.
Outbound calls are perfectly fine. But when i call inbound, call is answered and say " the account is already in use " i believe the calls returns to the service provider.
I have pasted my config and voice ccapi inout logs.
Thanks in advance.
! NVRAM config last updated at 11:27:07 UTC Sun Apr 28 2013 by admin
version 15.1
hostname vg
boot-start-marker
boot-end-marker
card type e1 0 1
card type e1 0 3
logging buffered 51200 warnings
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
network-clock-participate wic 1
network-clock-participate wic 3
no ipv6 cef
ip source-route
ip cef
ip name-server 109.224.14.2
ip name-server 8.8.4.4
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-2352337280
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2352337280
revocation-check none
rsakeypair TP-self-signed-2352337280
crypto pki certificate chain TP-self-signed-2352337280
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32333532 33333732 3830301E 170D3132 30393231 30383136
  35395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33353233
  33373238 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C099 B93F12CD 4EFA651A A05BE975 53555405 99E120BF 7D6170A0 69A8DB8A
  08829258 E8B28DCB 697DDDE9 949CE9AB FAF0757B 4491CFF7 09845D33 C0B7CC30
  8075CBA3 E9220155 B7C380B1 D5C00594 748B4738 21D1A314 C6B7FEA4 94F6049C
  F2B31AF1 C900C772 40F17730 F3AE3FEF 313C9865 C755564A 15160745 076F6EB8
  C2330203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 143CAEF9 ED4CF574 58F5DBE3 96FF4ECC 526A58A1 4D301D06
  03551D0E 04160414 3CAEF9ED 4CF57458 F5DBE396 FF4ECC52 6A58A14D 300D0609
  2A864886 F70D0101 05050003 81810074 90753884 B9A99263 CE4F9901 6B8E7B58
  82662C80 3041198B 9F3C0F4F 3382E81C FBA6AC64 8F0ABE88 3F355461 86296B52
  44CDA1FB 74093D48 1746B528 EA584D22 D9F42C77 1B6FAB15 58A0FBDA FCB4D112
  AB1E14C6 564A91DE D6B3BF0E FEDFF548 397317C9 8A28BF06 ADD772AC C0D1B810
  E817DF5F A0925C97 56FDA2BD 4D48FC
        quit
voice-card 0
dspfarm
voice service voip
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
voice translation-rule 10
rule 1 /141458*848374/ /55555/
rule 2 /(+442920003853\)/ /55555/
rule 3 /00442920003853/ /55555/
rule 4 /.*/ /55555/
voice translation-rule 11
rule 1 /.*/ /50106/
voice translation-profile SIP
translate called 10
voice translation-profile test
translate called 11
translate redirect-called 50106
license udi pid C3900-SPE150/K9 sn FOC1634B5S5
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 3
hw-module sm 4
redundancy
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/1/1
controller E1 0/3/0
controller E1 0/3/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.16.4.2 255.255.254.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 109.224.23.36 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 109.224.23.33
ip route 66.152.187.165 255.255.255.255 109.224.23.33
ip route 172.16.0.0 255.255.0.0 172.16.4.1
nls resp-timeout 1
cpd cr-id 1
control-plane
call threshold global cpu-avg low 68 high 75
call threshold global total-mem low 75 high 85
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0:15
cptone AE
bearer-cap Speech
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 3/0/0
voice-port 3/0/1
voice-port 3/0/2
voice-port 3/0/3
voice-port 3/0/4
voice-port 3/0/5
voice-port 3/0/6
voice-port 3/0/7
voice-port 4/0/0
voice-port 4/0/1
voice-port 4/0/2
voice-port 4/0/3
voice-port 4/0/4
voice-port 4/0/5
voice-port 4/0/6
voice-port 4/0/7
no ccm-manager fax protocol cisco
mgcp call-agent callmanger 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 2 voip
description *** Outbound Calls ***
destination-pattern .T
session protocol sipv2
session target ipv4:66.152.187.165:5060
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3 voip
description ***  Extensions ***
destination-pattern 50106
session target ipv4:172.16.4.10:5060
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 100 voip
description *** Incoming Dial-Peer from cucm ***
session target sip-server
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
description *** Incoming Dial-Peer ***
translation-profile incoming test
incoming called-number 141458*848374
voice-class codec 1
dtmf-relay rtp-nte
no vad
gateway
timer receive-rtp 1200
sip-ua
credentials username 141458*848374 password 7 040259xxxx realm 66.152.187.165
authentication username 141458*848374 password 7 10175Bxxxx
registrar dns:sip1.catiphone.com expires 3600
sip-server dns:sip1.catiphone.com
gatekeeper
shutdown
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
banner exec ^C
--------------------- Debug voice CCAPI INOUT ------------------------------------------------
May  2 12:21:18.104: //-1/A004F23983FF/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=001111
   ----- ccCallInfo IE subfields -----
   cisco-ani=001111
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=141458*848374
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdn=+442920003853
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=15   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
May  2 12:21:18.104: //-1/A004F23983FF/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x13652174, Call Info(
   Calling Number=001111,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=141458*848374(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=101, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=20013
May  2 12:21:18.104: //-1/A004F23983FF/CCAPI/ccCheckClipClir:
   In: Calling Number=001111(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=001111(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
May  2 12:21:18.104: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May  2 12:21:18.104: :cc_get_feature_vsa malloc success
May  2 12:21:18.104:  cc_get_feature_vsa count is 1
May  2 12:21:18.104: :FEATURE_VSA attributes are: feature_name:0,feature_time:337841208,feature_id:1591
May  2 12:21:18.104: //20013/A004F23983FF/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=001111(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=141458*848374(TON=Unknown, NPI=Unknown))
May  2 12:21:18.108: //20013/A004F23983FF/CCAPI/cc_process_call_setup_ind:
   Event=0x13B92FF8
May  2 12:21:18.108: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 141458*848374
May  2 12:21:18.108: //20013/A004F23983FF/CCAPI/ccCallSetContext:
   Context=0x12F25918
   >>>>CCAPI handed cid 20013 with tag 101 to app "_ManagedAppProcess_Default"
May  2 12:21:18.108: //20013/A004F23983FF/CCAPI/ccCallProceeding:
May  2 12:21:18.108: //20013/A004F23983FF/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3, Params=0x12F2AC68, Progress Indication=NULL(0)
May  2 12:21:18.108: //20013/A004F23983FF/CCAPI/ccCheckClipClir:
   Destination Pattern=50106, Called Number=50106, Digit Strip=FALSE
   Called Number=50106(TON=Unknown, NPI=Unknown),
   Redirect Number=+442920003853, Display Info=001111
   Account Number=001111, Final Destination Flag=TRUE,
   Guid=A004F239-B259-11E2-83FF-C8537EAB7692, Outgoing Dial-peer=3
May  2 12:21:18.108: //20013/A004F23983FF/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=001111
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=50106
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
May  2 12:21:18.108: //20013/A004F23983FF/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x13652174, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=001111,(Calling Name=001111)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=50106(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
May  2 12:21:18.108: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May  2 12:21:18.108: :cc_get_feature_vsa malloc success
May  2 12:21:18.108:  cc_get_feature_vsa count is 2
May  2 12:21:18.108: :FEATURE_VSA attributes are: feature_name:0,feature_time:337841880,feature_id:1592
May  2 12:21:18.108: //20014/A004F23983FF/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May  2 12:21:18.108: //20014/A004F23983FF/CCAPI/ccCallSetContext:
   Context=0x12F2AC18
May  2 12:21:18.108: //20013/A004F23983FF/CCAPI/ccSaveDialpeerTag:
May  2 12:21:18.108: //20014/A004F23983FF/CCAPI/cc_api_call_proceeding:
   Interface=0x13652174, Progress Indication=NULL(0)
May  2 12:21:18.112: //20014/A004F23983FF/CCAPI/cc_api_call_disconnected:
   Cause Value=63, Interface=0x13652174, Call Id=20014
   Call Entry(Responsed=TRUE, Cause Value=63, Retry Count=0)
May  2 12:21:18.112: //20013/A004F23983FF/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
May  2 12:21:18.112: //20014/A004F23983FF/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=20014
May  2 12:21:18.112: //20014/A004F23983FF/CCAPI/ccCallDisconnect:
   Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=63)
   Cause Value=63, Call Entry(Responsed=TRUE, Cause Value=63)
May  2 12:21:18.112: //20014/A004F23983FF/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x13652174, Tag=0x0, Call Id=20014,
   Call Entry(Disconnect Cause=63, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
May  2 12:21:18.112: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May  2 12:21:18.112: :cc_free_feature_vsa freeing 14230ED0
May  2 12:21:18.112:  vsacount in free is 1
May  2 12:21:18.112: //20013/A004F23983FF/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2, Params=0x16ED8A60, Progress Indication=NULL(0)
May  2 12:21:18.112: //20013/A004F23983FF/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=50106, Digit Strip=FALSE
   Guid=A004F239-B259-11E2-83FF-C8537EAB7692, Outgoing Dial-peer=2
May  2 12:21:18.112: //20013/A004F23983FF/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=001111
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=50106
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
May  2 12:21:18.112: //20013/A004F23983FF/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2, Call Count On=FALSE,
May  2 12:21:18.112: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May  2 12:21:18.112: :cc_get_feature_vsa malloc success
vg(cfg-translation-profile)#
May  2 12:21:18.112:  cc_get_feature_vsa count is 2
May  2 12:21:18.112: :FEATURE_VSA attributes are: feature_name:0,feature_time:337841880,feature_id:1593
May  2 12:21:18.112: //20015/A004F23983FF/CCAPI/ccIFCallSetupRequestPrivate:
May  2 12:21:18.112: //20015/A004F23983FF/CCAPI/ccCallSetContext:
   Context=0x16ED8A10
May  2 12:21:18.112: //20013/A004F23983FF/CCAPI/ccSaveDialpeerTag:
May  2 12:21:18.112: //20015/A004F23983FF/CCAPI/cc_api_call_proceeding:
May  2 12:21:18.848: //20015/A004F23983FF/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=20015,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
May  2 12:21:18.848: //20013/A004F23983FF/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=20013,
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=1)
May  2 12:21:18.848: //20015/A004F23983FF/CCAPI/cc_api_event_indication:
   Event=171, Call Id=20015
   Event Is Sent To Conferenced SPI(s) Directly
   Event=98, Call Id=20015
May  2 12:21:18.848: //20015/A004F23983FF/CCAPI/cc_api_call_cut_progress:
   Interface=0x13652174, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
   Call Entry(Responsed=TRUE)
May  2 12:21:18.848: //20013/A004F23983FF/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
May  2 12:21:18.848: //20013/A004F23983FF/CCAPI/ccConferenceCreate:
   (confID=0x12C6420C, callID1=0x4E2D, gcid=A004F239-B25911E2-8402C853-7EAB7692, tag=0x0)
May  2 12:21:18.848: //20015/A004F23983FF/CCAPI/ccConferenceCreate:
   (confID=0x12C6420C, callID2=0x4E2F, gcid=A004F239-B25911E2-8402C853-7EAB7692, tag=0x0)
   Conference Id=0x12C6420C, Call Id1=20013, Call Id2=20015, Tag=0x0
May  2 12:21:18.848: //20013/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May  2 12:21:18.848: cc_api_get_xcode_stream : 4702
May  2 12:21:18.848: //20015/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May  2 12:21:18.848: ccConferenceCreate: ret1=0, codecMask1=4, bytes1=20, negot1=1, dtmf1=6
                    ret2=0, codecMask2=4, bytes2=20, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=18, rx_dynamic_pt1=18, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=18, rx_dynamic_pt2=18, codec_mode2=0, params_bitmap2 =0
   delay media to slow start case, codec negotation is not done
May  2 12:21:18.848: //20013/A004F23983FF/CCAPI/cc_api_bridge_done:
   Conference Id=0xEB, Source Interface=0x13652174, Source Call Id=20013,
   Destination Call Id=20015, Disposition=0x0, Tag=0x0
May  2 12:21:18.848: //20015/A004F23983FF/CCAPI/cc_api_bridge_done:
   Conference Id=0xEB, Source Interface=0x13652174, Source Call Id=20015,
   Destination Call Id=20013, Disposition=0x0, Tag=0x0
May  2 12:21:18.848: //20013/A004F23983FF/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xEB, Destination Call Id=20015)
   Call Entry(Conference Id=0xEB, Destination Call Id=20013)
May  2 12:21:18.848: //20013/A004F23983FF/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xEB, Call Id1=20013, Call Id2=20015
May  2 12:21:21.616: //20015/A004F23983FF/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x13652174, Call Id=20015
   Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
May  2 12:21:21.616: //20013/A004F23983FF/CCAPI/ccCallReleaseResources:
May  2 12:21:21.616: //20015/A004F23983FF/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=20015
May  2 12:21:21.616: //20013/A004F23983FF/CCAPI/ccConferenceDestroy:
   Conference Id=0xEB, Tag=0x0
May  2 12:21:21.616: //20013/A004F23983FF/CCAPI/cc_api_bridge_drop_done:
May  2 12:21:21.616: //20015/A004F23983FF/CCAPI/cc_api_bridge_drop_done:
May  2 12:21:21.616: //20013/A004F23983FF/CCAPI/cc_generic_bridge_done:
May  2 12:21:21.616: //20015/A004F23983FF/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
May  2 12:21:21.616: //20015/A004F23983FF/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x13652174, Tag=0x0, Call Id=20015,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
May  2 12:21:21.616: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May  2 12:21:21.616: :cc_free_feature_vsa freeing 14230ED0
May  2 12:21:21.616:  vsacount in free is 1
May  2 12:21:21.616: //20013/A004F23983FF/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
May  2 12:21:21.880: //20013/A004F23983FF/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x13652174, Tag=0x0, Call Id=20013,
May  2 12:21:21.880: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May  2 12:21:21.880: :cc_free_feature_vsa freeing 14230C30
May  2 12:21:21.880:  vsacount in free is 0
Please post "debug ccsip messages"
Chris
