Translation profile not working
hunt
Dear all,
My customer wants to translate all the inbound PSTN calls from 10 digits to internal 4 digits extensions e.g 7882
Although I can test my voice translation rule fine, it just doesn't seem to match when a PSTN call comes in.
In my customer environment, the telco gives my customer 10 digit numbers.  e.g. 0293917882.  Now, all my customer's IP Phone only has 4 digit extensions, so it is 7882.
TSCVOIP050#test voice translation-rule 12 0293917882
Matched with rule 1
Original number: 0293917882     Translated number: 7882
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
TSCVOIP050#
I have the following translation profile rules on the voice gateway:-
voice translation-rule 11
rule 1 /\(^.*\)/ /0\1/
rule 1 /^029391\(....\)/ /\1/
voice translation-profile inboundpstn
translate calling 11
translate called 12
And i have applied it on my inbound dial peer.
dial-peer voice 1 pots
translation-profile incoming inboundpstn
incoming called-number .
direct-inward-dial
But when an incoming call comes in when i tried to dial 0293917882, it doesn't get translate at all and i get an unallocated number error.
*Aug 16 07:29:29.551: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0E19
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA1838A
                Preferred, Channel 10
        Calling Party Number i = 0x2183, '0438755818'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '0293917882'
                Plan:ISDN, Type:Subscriber(local)
        Sending Complete
*Aug 16 07:29:29.551: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8E19 callID =
0x0020 switch = primary-net5 interface = User
*Aug 16 07:29:29.555: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8E19
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
*Aug 16 07:29:29.563: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x8E19
        Cause i = 0x8181 - Unallocated/unassigned number
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Aug 16 07:29:33.547: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0E19
        Cause i = 0x8090 - Normal call clearing
*Aug 16 07:29:33.547: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8E19
*Aug 16 07:29:33.595: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0E19
Would appreciated any help.
CHeers,
Hunt
9 Replies 9
acampbell
Could you test a simpler translation on the voice port.
Replace the numbers with your own scheme.
voice translation-rule 100
!###THIS TRANLATES I/C DIGITS
Rule 1 /0293917/ /7/
voice translation-profile INCOME-PSTN
translate called 100
voice-port 0/0:15
translation-profile incoming INCOME-PSTN
Can you let us know if this works
Alex
Regards, Alex. Please rate useful posts.
Marwan ALshawi
Hi Hunt
your tranlsation look sok could you please do the follwoing change to your voice gateway config and try it again and if dose not work post the debug of the VOIP dialpeer
direct-inward-dial
destination-pattern 0T
port 0/0/0:15
NO dial-peer voice 2 pots
if helpful Rate
is it fixed ?
Johan Leuyckx
I'm having the same issue... It is as if the translation profile is just not there...
Did you find a solution?
For me, moving the translation profile to the voice-ports is not an option...
Johan
Hi Johan
can you post your config here
Basically it is the config below. We have OVERLAP receiving...
To me, this triggers the problem. If we send dial from a cell phone "en block" and receive all digits in one setup message, the the translation works just fine...
and the digits come in faster then the 3 second delay I configured...
dial-peer voice 5 pots
description *** DP for incoming calls ***
translation-profile incoming TRANSLATE
incoming called-number .T
direct-inward-dial
port 0/0/0
voice translation-profile TRANSLATE
translate calling 1
translate called 2
rule 1 // /0&/
voice translation-rule 2
rule 1 /^309911300/ /5410/
rule 2 /^309911301/ /5411/
rule 3 /^3099113\(..\)/ /54\1/
rule 4 /^309911/ /5410/
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving T302 3000
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
yes you right the overlap receiving causing the translation-matching
do you mean by using the delay your issue fixed ?
i am sure might had look at the bellow link regarding the isdn overlapping
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a00800b48cb.shtml
Hi Johan,
As you found out you can not use translation pattern on inbound dial-peers when using overlap receiving; the reason for this is that IOS needs to allocate memory for the call and it 'matches' already a dial-peer with the first part of the called number and here your translation pattern does not match.
Kristof
Hi Kristof,
Is there some official doc available stating that the two cannot be combined? Any known workaround?
As in a CCIE voice lab, it seems to work just fine... But with mine, it doesn't...
If I configure the incoming called number as simply a ".", it seems to work, but people complain that from time to time it still goes wrong. Think it doesn't wait for the t302 timer then...
Thx
Johan
