translation-profile vs translate-outgoing
Dronskiy [more]2013-05-28 23:39:27
Hello!
ISR 2901 when switching to CME-SRST. Dial peer with translation-profile digit manipulation work correct, but with translate-outgoing don't working. I don't understand why?
voice translation-rule 1
  rule 1 /73../ /xxxxxx/ type any subscriber
voice translation-profile OUT
translate calling 1
#working
dial-peer voice 1 pots
  description Local calls(Subscriber)
  destination-pattern 9[1-9]......
  translation-profile outgoing OUT
  port 0/0/0:15
  forward-digits 7
#not working
  translate-outgoing calling 1
  port 0/0/0:15
  forward-digits 7
Chris Deren
When you use translate-outgoing that means you are attempting to invoke a translation rule not a voice translation-rule, which you have not defined. Basically you should use the method 1 which is newer and more flexible.
HTH,
Chris
Chris Deren
HTH,
Chris
