I have a CUCM server running on version 7, we want to upgrade it to version 8. As of now it is not covered under UCSS.
Can you please tell me which license SKU should i order for this upgrade?
Andy
Hi Andy,
Firstly,you need to have a valid ESW contract before u place the order for UCSS.
You need to look into whether u are using MCS Hardware/ UCS platform since CUCM 8.0(2) above requires min. 4 GB of DRAM.
You need to speak to Cisco SE to have exact PArt Codes so as to avoid any wrong ordering.
regds,
aman
Andersson,
As mentioned by Aman, there has been huge change since 8.x version. You have to check the software availability and hardware compatibility. Better you check with your SE for the exact support.
TT
Rate helpful posts
Hi Andy
If your system is not covered by UCSS (even if you do have ESW) you won't be allowed to buy it by Cisco. UCSS is only available on new installs for a short period. After this, you can't buy it for existing systems.
Your most cost effective option will be to upgrade by the "9+3" upgrade which will get you to the latest version for RRP $9 per user when you buy 3 years of UCSS and ESW at the same time.
Part codes:
MIG-CUCM-ENHP Migration to UC Manager 9.x Enh Plus
MIG-CUCM-USR Migration to UC Manager Enhanced
MIG-CUCM-BASIC Migration to UC Manager Basic
MIG-CUCM-ESS-USR Migration to UC Manager Essential
MIG-TP-ROOM Migration to UC Manager TelePresence Room based endpoint
Barry Hesk
Intrinsic Network Solutions
