Translation profiles Incoming & Outgoing
clark white
Level 2
Level 2
Dears,
The below translation profile is for outbound calls from the corporate which is having a 8 digit numbering plan the result for below translation profile is the digit which will go to ITSP are 8.. This means ITSP is accepting only 3 digit from me, please correct me if i am wrong.
voice translation-rule 1
rule 1 /0\([8]..\)/ /\1/
INCOMING TRANSLATION
i Have a 4 digit extension plan starting with 3XXX
The below Incoming Translation profiles will replace 214555 to 3...
voice translation-rule 1   rule 1 /^214555\(3...\)$/ /\1/
The above translation can also be configured in diffrent way, Is the both way are correct???
rule 1 /^2145553/ /3/
Can anybody route me to goof link of tutorial for trnaslation profiles.
2 Accepted Solutions
Hi Clark.
your first translation rule would translate a dialed number as 08XX with 8XX
The second will not work in that format.
you have rule 1 /^214555\(3...\)$/ /\1/
should be
rule 1 /^214555\(3...$\)/ /\1/   to trnaslate 2145553XXX into 3xxx
or,as you correctly mentioned, could be:
Please use this useful link as reference.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi.
The rule
is also correct, it will translate 2145553 with 3 followed by a variable number of digits
Here some tests
test voice translation-rule 1 214555300000
Matched with rule 1
Original number: 214555300000          Translated number: 300000
Original number type: none          Translated number type: none
Original number plan: none          Translated number plan: none
Matched with rule 1
Original number: 21455530          Translated number: 30
Carlo
6 Replies 6
Hi Clark.
should be
Carlo
Ayodeji Okanlawon
Clark,
This rule is correct and will change all numbers beginning with 2145553... to a 4 digit number eg 2145553000 to 3000
This rule isnt correct and wont work. This will change the number 2145553 to 3..only
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi.
The rule
Here some tests
Matched with rule 1
Matched with rule 1
Carlo
Dears,
I have a 8 digit numbering plan in my country, ITSP gave me 100 DID for example 232323XX - 399
I am setting up a new SIP trunk connection to the ITSP , i dont have any information whether the ITSP is forwarding only 3 Digit  or accepting only 3 digit from my end , how i will come to know ??? which debug i have to enable to know this information.
Ideally you should have confirmed this with your ITSP..but you can use debug ccsip messages or debug voip ccapi inout
Dears,
Thanks all for your replies.
