Translation rule to strip digits
Tomas Mazur
I am trying to add a new voice translation rule to our CUBE in order to strip some incoming digits.
Router IOS is Version 15.7(3)M4b (2901).
I would like to strip all but the last 3 incoming digits  on number +499874565XXX.
When I try to add the translation rule below I get error:
DE-PSTN-01(config-translate)#rule 1 /^.*\(...\)/ /\1/
Incorrect format for Translation Match Pattern
        regular expression must be of the form  ^(\^)?(\+)?([0-9,A-F.*%?#]+)$
 Invalid match pattern string input /^.*\(...\)/
I have taken this particular example from an online forum which was written in 2011 so not entirely sure if the syntax has changed or if its a bug?
Tomas Mazur
Just realized I was missing "voice" in front of the translation-rule command. voice translation-rule 201 rule 1 /^.*\(...\)/ /\1/ Works like a charm.
Tomas Mazur
