SIP/2.0 488 Not Acceptable Media on Cisco router
Tomas Mazur
Could someone explain how can I go about matching codecs or transcoding SIP calls between Deutsche Telekom and our endpoints.
We are in the process of migrating from ISDN to SIP trunk provided by Dutsche Telekom (DT). I am currently facing issue with external calls not connecting due to codec mismatch.
Basic topology is this:
DT <SIP trunk> CUBE on Cisco 2901 < SIP trunk> CUCM 9.1 <-> Cisco 7942 phones or Jabber
Codecs offered by DT are 1) G.711alaw and 2) g722-64.
Codec used on SIP trunk between CUCM and CUBE is G.711ulaw.
This is the config I have so far for dial-peers and codecs
voice-card 0
 dspfarm
 dsp services dspfarm
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g722-64
dspfarm profile 1 transcode universal
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 codec g722-64
 maximum sessions 6
 associate application CUBE
dial-peer voice 3000 voip
 description <<Incoming from Deutsche Telekom>>
 session protocol sipv2
 incoming called e164-pattern-map 3000
 voice-class codec 1
 voice-class sip early-offer forced
 voice-class sip bind control source-interface ATM0/1/0.7
 voice-class sip bind media source-interface ATM0/1/0.7
 dtmf-relay rtp-nte sip-notify
 no vad
dial-peer voice 3010 voip
 description <<From CUBE to Deutsche Telekom>>
 session transport tcp
 destination e164-pattern-map 3010
 voice-class codec 1
 voice-class sip outbound-proxy dns:reg.sip-trunk.telekom.de
 dtmf-relay rtp-nte
 ip qos dscp cs6 signaling
 clid strip name
 no vad
dial-peer voice 2000 voip
 description <<Incoming from CUCM to CUBE>>
 incoming uri via 2000
 voice-class sip bind control source-interface GigabitEthernet0/0
 voice-class sip bind media source-interface GigabitEthernet0/0
 codec g711ulaw
 no vad
dial-peer voice 2010 voip
 description <<From CUBE to CUCM>>
 session server-group 1
 destination e164-pattern-map 2010
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
Transcoder appears to be registered:
#show dspfarm profile
Dspfarm Profile Configuration
 Profile ID = 1, Service =Universal TRANSCODING, Resource ID = 1
 Profile Service Mode : Non Secure
 Profile Admin State : UP
 Profile Operation State : ACTIVE
 Application : CUBE   Status : ASSOCIATED
 Resource Provider : FLEX_DSPRM   Status : UP
 Total Number of Resources Configured : 6
 Total Number of Resources Available : 6
 Total Number of Resources Out of Service : 0
 Total Number of Resources Active : 0
 Codec Configuration: num_of_codecs:6
 Codec : g722-64, Maximum Packetization Period : 30
 Codec : g729r8, Maximum Packetization Period : 60
 Codec : g711ulaw, Maximum Packetization Period : 30
 Codec : g711alaw, Maximum Packetization Period : 30
 Codec : g729ar8, Maximum Packetization Period : 60
 Codec : g729abr8, Maximum Packetization Period : 60
When making external calls to the router I keep getting these SIP messages:
Invite
195101: .Jun 21 17:48:37.663: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+49896161350@217.86.242.157:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 217.0.15.67:5060;branch=z9hG4bK366fcc655e8cc5082f9bc0d550b43293.b142a213
Record-Route: <sip:reg.sip-trunk.telekom.de;transport=tcp;lr>
Max-Forwards: 58
To: +498961613515 <sip:+498961613515@telekom.de;transport=udp;user=phone>
From: <sip:+447812344567@sip-trunk.telekom.de;transport=udp;user=phone>;tag=b0fc111f
Call-ID: 319f1a3b6d0b94e4@62.156.103.70
Contact: <sip:WRp/ESjOusBGBNYFgfgmFAnbj/0a+sQrAyTP17gbWvLBqzeW6wiU7y2UMx7MDvII@th1>
Supported: 100rel,199,histinfo,timer
Session-Expires: 1800;refresher=uac
CSeq: 12084580 INVITE
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, REGISTER, UPDATE
Min-SE: 900
P-Asserted-Identity: <sip:+447885539326@sip-trunk.telekom.de;user=phone>
P-Called-Party-ID: <sip:+498951513515@sip-trunk.telekom.de;user=phone>
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 432
v=0
o=- 1172086142 1172086143 IN IP4 217.0.15.67
s=on transit
c=IN IP4 217.0.132.9
t=0 0
m=audio 13536 RTP/AVP 8 101 0 108 102 18 4 109
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:108 AMR/8000
a=fmtp:108 mode-change-neighbor=1;mode-change-period=2;mode-change-capability=2
a=rtpmap:102 AMR/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:109 G726-16/8000
a=ptime:20
To which router replies with:
195102: .Jun 21 17:48:37.671: //6541/4011C65094C1/SIP/Msg/ccsipDisplayMsg:
Sent:
From: <sip:+447123456789@sip-trunk.telekom.de;transport=udp;user=phone>;tag=b0fc111f
To: +498961613515 <sip:+498961613515@telekom.de;transport=udp;user=phone>;tag=B9E0678-2399
Date: Fri, 21 Jun 2019 16:48:37 GMT
Allow-Events: telephone-event
Reason: Q.850;cause=65
Server: Cisco-SIPGateway/IOS-15.7.3.M4b
Session-ID: 19d007e73ede5f588f709999fb11c32d;remote=d1a3d045f65950738b30736054c52285
Content-Length: 0
I am attaching SIP debug from the router for those interested.
Thanks for any suggestions
Tom
7 Replies 7
A couple of questions:
First, is the CUBE attempting to signal to CUCM and then sending the 488 response back to the ITSP? Or is the 488 response the first action the router takes after receiving the INVITE?
Second, you say the DT is offering G77alaw and G722, but I don't see G722 in the rtpmap in the INVITE. (And if I'm correct, removing G722 from the voice class codec 1 might fix the problem.)
Third, (because I'm curious), what is causing you to use g711ulaw on the CUCM side?
Maren
Hi Maren,
To answer your questions:
1) Based on the ccsip debug it appears the call never makes it to the CUCM. I have also checked on CUCM via real time session trace and there are no incoming calls. I am attaching picture of debug from translator-X FYI.failed call.png
2) I used codecs based on this document by Cisco - Connecting CUCM 11.5.1 to DT All IP SIP trunks PDF
It was surprising to see all of those being advertised in the IVITE message - not entirely sure why that is as Deutsche Telekom's and Cisco docs both state that only two codecs are supported. I followed your suggestion and removed G722 from the voice codec class. Still getting the 488 response though. - Should I try G722 across the entire call path instead?
3) This was not a design decision - I simply followed the guide I listed above and left it at defaults.
Another test I have run just now was:
On CUCM:
  • tick Media Termination Point Required
  • Select 711alaw in MTP Preferred Originating CodecRequired Field
On CUBE:
  •  update both CUCM dial peers to only use codec 711alaw
I then made few calls and all go the same - there is silence for few seconds and call disconnects without any dial tone or message.
Supported codecs: G722 + G711a-Law
The negotiation of other codecs between two IP-PBXs is not prevented. Over network boundaries, codecs beyond the default codec G.711 may not be usable.
Any other ideas?
Thanks Tom
Hi Maren,
1) Based on the ccsip debug it appears the call never makes to the CUCM. I have also checked on CUCM via real time session trace and there are no incoming calls. I am attaching picture of debug from translator-X FYI.failed call.png
2) I used codecs based on this document by Cisco - Connecting CUCM 11.5.1 to DT All IP SIP Trunks via CUBE 11.5.2
I followed your suggestion and removed G722 from the voice codec class. Still getting the 488 response though. Should I try using G722 across all call paths?
On CUCM:
  * tick Media Termination Point Required
  * Select 711alaw in MTP Preferred Originating CodecRequired Field
On CUBE:
 * update both CUCM dial peers to only use codec 711alaw
I then made few calls and all go the same - there is silence for few seconds and call drops.
This is excerpt from DT's technical doc (in German):
Supported codecs:
G722 + G711a-Law
Any other ideas??
Tom
Ok, so we know that the CUBE itself has the issue rather than a disagreement between the CUBE and CUCM.
I'm less worried about the G722 on the telco side than I am about the mis-matched alaw-ulaw on the CUBE. I was hoping that removing the G722 on the telco side would allow the CUBEs transcoder to fix the problem, but obviously it didn't.
My next suggestion would be to force g711alaw on both the DK-facing dial peers and the CUCM-facing dial peers. And, in CUCM set up a custom codec selection list that favors a-law over u-law and apply it to the region connecting the phones with the trunk. With everything using a-law only (and you want to get rid of the tick on the MTP Required if you have CUCM 9 or later - that is no longer a recommended practice) we will know if the problem is codec selection or something else.
Maren
Hello Maren,
I have followed all of your suggestions however calls are still dropped with the same 488 error message.
Any other suggestions?
Tom
Make sure you force the inbound dialpeer on cube to use g711 only. So the external inbound call gets forced on g711. The the outbound dialpeer to cucm forced to g711 too.
Please remember to rate useful posts, by clicking on the stars below.
Are you sure the incoming call from the ITSP is matching the correct dial peer?
