Trouble getting 8821 to register with Fast Track on 2901
MarkhamBledsoe
I'm trying to get a 8821 registered on a 2901 using Fast Track.  I cannot seem to get the phone registered.  Any help would be appreciated.
2801 running Version 15.4(3)M3.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
call start slow
sip
bind control source-interface GigabitEthernet0/0.100
bind media source-interface GigabitEthernet0/0.100
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g722-64
codec preference 3 ilbc
codec preference 4 g729r8
codec preference 5 g723r63
codec preference 6 g723r53
voice class h323 1
h225 timeout tcp establish 3
voice class sip-profiles 1
voice register pool-type 8821
xml-config maxNumCalls 4
xml-config busyTrigger 2
phoneload-support
transport tcp
num-lines 2
description Cisco IP Phone 8821
reference-pooltype 9971
voice register global
mode cme
source-address 192.168.100.254 port 5060
max-dn 100
max-pool 20
load 8821 sip8821.11-0-5SR1-4.loads
authenticate register
tftp-path flash:
create profile sync 2280551830134653
voice register dn 1
number 1152
name Production Room
label 1152-Production
voice register dn 2
number 2152
name Intercom Production Room
label Intercom - Production Room
voice register pool 1
id mac ACF5.367B.9D36
session-transport tcp
type 8821
number 1 dn 1
number 6 dn 2
dtmf-relay rtp-nte
codec g711ulaw
paging-dn 39
******#sh voice register tftp-bind
tftp-server url flash:/its/syncinfo.xml alias syncinfo.xml
tftp-server url flash:/its/SIPDefault.cnf alias SIPDefault.cnf
tftp-server url flash:/its/softkeyDefault_kpml.xml alias softkeyDefault_kpml.xml
tftp-server url flash:/its/softkeyDefault.xml alias softkeyDefault.xml
tftp-server url flash:/its/featurePolicyDefault.xml alias featurePolicyDefault.xml
tftp-server url flash:/its/SEPACF5367B9D36.cnf.xml alias SEPACF5367B9D36.cnf.xml
#debug ccsip message
Feb 6 23:17:08.987 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:192.168.100.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.124:5060;branch=z9hG4bK510468cf
From: "" <sip:@192.168.100.124>;tag=acf5e67b9d3604846bb9e86f-0a325a9d
To: <sip:192.168.100.254>
Call-ID: acf5e67b-9d360484-3aea8ec6-616e72a1@192.168.100.124
Session-ID: 0b17ff4600105000a000acf5e67b9d36;remote=00000000000000000000000000000000
Date: Fri, 07 Feb 2020 05:17:09 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP8821/11.0.5
Expires: 10
Max-Forwards: 70
Contact: <sip:@192.168.100.124:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPACF5E67B9D36"
Require: norefersub
Referred-By: "" <sip:@192.168.100.124>
Refer-To: cid:6051a56f@192.168.100.124
Content-Id: <6051a56f@192.168.100.124>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 1366
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceName">SEPACF5E67B9D36</String>
<String name="DeviceIPv4Address">192.168.100.124/24</String>
<String name="IPv4DefaultGateway">192.168.100.254</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-8821</String>
<String name="NeighborIPv4Address"></String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID"></String>
<String name="NeighborPortID"></String>
<Enum name="DHCPv4Status">1</Enum>
<Enum name="DHCPv6Status">3</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">4</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<Enum name="DNSv6StatusUnifiedCM1">0</Enum>
<Enum name="DNSv6StatusUnifiedCM2">0</Enum>
<Enum name="DNSv6StatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN"></String>
<String name="UnifiedCMIPAddress"></String>
<String name="LocalPort"></String>
<String name="TimeStamp">1579286362969</String>
<Enum name="ReasonForOutOfService">107</Enum>
<String name="LastProtocolEventSent"></String>
<String name="LastProtocolEventReceived"></String>
<String name="ReasonForOutOfServiceText">LastTimeUpgrade</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Feb 6 23:17:08.991 CST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
******#SIP/2.0 400 Bad Request
To: <sip:192.168.100.254>;tag=BE27EB00-23E2
Date: Fri, 07 Feb 2020 05:17:08 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M3
CSeq: 1000 REFER
Content-Length: 0
Contact: <sip:192.168.100.254:5060>
Leo Laohoo
Is the phone joining the wireless or not?
Yes, it is on the voice vlan wireless. It is getting an IP address in the same scope as CME.
Any other suggestions?  I'm at a loss.
