trunk between CUCM and Yeaster PBX
mhmadabdallah91
dears
we set trunk between cucm 12.5 and yeaster pbx
when call from cucm ext the yeaster EXT. ring but we cant hear us
when yeater try to call cucm receive MSG not found
can any one help me.
when call from cucm ext the yeaster EXT. ring but we cant hear us:- Could be due to Routing. Check if you can ping Phone subnets. When Pining make sure you ping both side.
when yeater try to call cucm receive MSG not found:- Check if you have configured proper  inbound calling search space which can reach CUCM phones.
Response Signature
thanks for your reply
Check if you can ping Phone subnets. (the two subnets are ping )
can you explain its from yeaster or cucm side
If both subnets are pining, what codec you use between these trunks ? try to use  same codec. Is there a Firewall in between ?
I can see large number of document in yeastar site with detailed steps on how to configure sip trunk between CUCM and yeastar. Did you verified those documents.
Its on your CUCM, On Trunk page Inbound select proper CSS which can reach  the phones.
Response Signature
