Showing results forĀ
Search instead forĀ
Did you mean:Ā
TRUNK SIP
jrfongang091
SALUT A TOUS
J'AI UNE PREOCUPATION
JE SOUHAITE CONNECTER LE CUCM 12.5 AU YEASTAR S300 AFIN DE  CONFIGURER UN TRUNK SIP
The Yeastar website has a number of documents showing how to create a SIP Trunk and configure call routing to pass calls between CUCM and Yeastar products. Start there.
One word of advice, though, is that you'll want to find newer documentation. Many of the documents show integrations between CUCM 8.x and Yeastar. You'll want to find integration documents from 9.x or later.
Once you have the basics in place, please post any additional questions or concerns you have.
Maren
Le site Web Yeastar contient un certain nombre de documents montrant comment crƩer une jonction SIP et configurer le routage des appels pour transmettre les appels entre les produits CUCM et Yeastar. Commencez par lƠ.
Un conseil, cependant, est que vous souhaiterez trouver une documentation plus rĆ©cente. De nombreux documents montrent des intĆ©grations entre CUCM 8.x et Yeastar. Vous souhaiterez trouver des documents dā€™intĆ©gration Ć  partir de 9.x ou version ultĆ©rieure.
Une fois que vous avez les bases en place, veuillez poster toutes vos questions ou prƩoccupations supplƩmentaires.
Maren
merci Maren.
je vais essayer avec les configuration qui sont dans le site web de yeastar bien que les modĆØles diffĆØre.
Generally speaking, a vendor will have all of their SIP Trunks have a common set of attributes/settings across their products. So the settings for the Yeastar end of the SIP Trunk for one product should be more or less the same for another product. This is true for CUCM as well and there is lots of documentation for those.
Give it a try. If it doesn't work gather screenshots of the configuration of each end of the trunk, along with a debug of the attempt at message exchange, and we can help you troubleshoot.
Maren
De maniĆØre gĆ©nĆ©rale, un fournisseur fera en sorte que toutes ses liaisons SIP aient un ensemble commun d'attributs/paramĆØtres pour l'ensemble de ses produits. Ainsi, les paramĆØtres de l'extrĆ©mitĆ© Yeastar du tronc SIP pour un produit devraient ĆŖtre plus ou moins les mĆŖmes pour un autre produit. Cela est Ć©galement vrai pour CUCM et il existe de nombreuses documentations Ć  ce sujet.
Essayez-le. Si cela ne fonctionne pas, rassemblez des captures d'Ć©cran de la configuration de chaque extrĆ©mitĆ© du tronc, ainsi qu'un dĆ©bogage de la tentative d'Ć©change de messages, et nous pourrons vous aider Ć  rĆ©soudre le problĆØme.
Maren
