Turn off IP Phone PC Port
Limitless1801
Hi there,
I would like to be able to determine those IP Phones in which the PC port is not in use and turn them off in a bulk. Is there any tool out there that allows me to do that?
Thanks, Rafael.
yahsiel2004
Level 7
Level 7
How many phones are you trying to check? The only way I can think of, is manually going to the web page of each phone.
Sent from Cisco Technical Support Android App
HTH Regards, Yosh
