Twilio incoming call fail on sip trunk on cucme
o0chris0o
I've been trying to resolve this problem for a few days now (I'm starting in the cisco voip). I set up a Twilio elastic SIP trunk, I'm able to make outside call, but the incoming calls are drop, when I call the number, it simply said that the number is not assign. But the call did reach my system, when I run the debug, I see it coming through but I get a SIP 404 not found with reason #1 (number not allocated). Before going further, here's my set up, Twilio--->CUCME (cisco router 2811)---->CUE (auto-attendant-202)---->SCCP extension.
The way I setup the call routing is when I call the main number (5145551212) the call is supposed answered by the AA at 202 then from there, the user choose an option then is transfer to either a huntgroup or a DN.
When I look at the logs I find out first that when it reach my translation-rule (/15145551212/ /202/) it actually translate it to +202, which I think is the problem. So I went on and read about it and I was able to get rid of the (+), but it goes nowhere from there, the rule to strip the (+) is apply but it doesn't go to 202. Then the call get stuck there so I don't know how to push the call through another translation-rule/profile to finish the leg.
Can you guys look at my config and point me where I might have screwed up?
Ayodeji Okanlawon
Hi there,
First of all you only need one inbound dial-peer in this scenario. So I suggest you remove dial-peer 101
no dial-peer voice 101 voip
Now, the translation profile applied to dial-peer 100 should look like this:
voice translation-rule 4
rule 1 /^\+5145551212/ /202/
If you want all calls coming to go to AA on 202, then you can use this
/^\(.*\)/ /202/
Please rate all useful posts
Ayodeji Okanlawon
Hi there,
/^\(.*\)/ /202/
Hi Ayodeji,
Thank you very much! It worked! Can you point me to a good ressource to learn more about translation rules.
Chris
