Two CME's together??
jelkin001
here is my delima,
I have two CME's in two separate locations with IP Connectivity between the two.
CME-A has my PSTN Connection and phones physicaly connected to as well as registered to it can dial out and to each other.
CME-B has a handful of phones connected to it and can call each other.
I need to be able to dial extensions between the two CME's as well as CME-B to utilize the PSTN Connection of CME-A
Main reason is that i have a requirement for analog phone connectivity at site B.  I could just have all the phones connect to site A, but i have no other way to get analog connectivity at site B.. Save an ATA that i cannot seem to get to register.
Any advise?  Config Examples?
9 Replies 9
Chris Deren
Simply create dial-peer on one side pointing to the other, and ensure you allow sip to sip or h323 to h323 calls depending on which protocol you are using.
HTH,
Chris
Do you have and config examples?  Cisco voice is a new concept to me...
xiaobaibc
Can you post your configurations of both CME-A& CME-B?
As Chris mentioned,
for allow sip to sip or h323 to h323, you can configure:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
For adding dial-peer on CME-B :
dial-peer voice 100 voip
destination-pattern xxx
session target ipv4:x.x.x.x(CME A)
For mor detail configuration, I need your current cfg for reference.
CME-A  Main site with current PSTN Connections (POTS ON FXO)   Waiting on T1 connection from Telco...
Currently all phones connect to this one as we are all still in the same building.  When we move to the new building this one will go with us and so will all the telco connectivity.
There will only be an ethernet connection between this building and the other.  Worse case CME-B only handles FXS ports for Fax...
Current configuration : 8150 bytes
! Last configuration change at 01:54:56 EDT Wed Sep 4 2013
! NVRAM config last updated at 16:31:37 EDT Wed Sep 4 2013
version 12.4
hostname PD_CME
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone eastern -5
clock summer-time EDT recurring
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip name-server 192.168.1.254
ip name-server 192.168.1.1
voice service voip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
max-dn 72
max-pool 24
create profile sync 001743334234122A
voice register dn  52
number 2025
voice translation-rule 2
rule 1 /^911$/ /911/
archive
log config
  hidekeys
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
description MANAGEMENT NETWORK
ip address 192.168.1.26 255.255.255.0
speed auto
full-duplex
ip default-gateway 192.168.1.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip http server
no ip http secure-server
ip http path flash:/gui
control-plane
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
timeouts call-disconnect 3
connection Tie-line 9712
caller-id enable
voice-port 1/1/1
ring number 3
connection Tie-line 3535
caller-id enable
dial-peer voice 1 pots
destination-pattern 9T
port 1/1/0
dial-peer voice 2 pots
port 1/1/1
telephony-service
load 7960-7940 P00308000800
load ATA ata030204sccp090202a
load 7911 SCCP11.9-0-3S
max-ephones 52
max-dn 208
ip source-address 192.168.1.26 port 2000
auto assign 100 to 105
timeouts interdigit 2
system message Police Department
cnf-file location flash:
max-conferences 8 gain -6
web admin system name admin password
dn-webedit
transfer-system full-consult
directory entry 1 92608837 name John Elkin - Cell
create cnf-files version-stamp 7960 Aug 30 2013 22:58:17
ephone-dn  1
number 1005
label Ext. 1005
description Sgt. J. Elkin
name PD-SGT J Elkin
hold-alert 30 originator
ephone-dn  2
number 9712
label 9712
description 9712
name Incoming Police 9712
ephone-dn  3
number 1001
label Ext. 1001
description Front Desk
name PD-Front Desk 2
ephone-dn  4
number 3535
label -3535
description -3535
name Town Hall 3535
ephone-dn  5
number 1000
label Ext. 1000
name PD-Front Desk 1
ephone-dn  6
number 1002
label Ext. 1002
description Evidence
name PD-Evidence
ephone-dn  7
number 2001
label Ext. 2001
description Jan
name TH-Janice Poole
ephone-dn  8
number 2002
label Ext. 2002
description Rh
name TH-Rhona Gunter
ephone-dn  9
number 1003
label Ext. 1003
description ID Room
name PD-ID Room
ephone-dn  10
number 1004
label Ext. 1004
description Supply Rm
name PD-Supply Room
ephone-dn  11
number 1006
label Ext. 1006
description Server Room
name PD-Server Room
ephone-dn  12
number 1007
label Ext. 1007
description Kitchen
name PD-Kitchen
ephone-dn  13
number 1008
label Ext. 1008
description Capt
name PD-Capt
ephone-dn  14
number 1009
label Ext. 1009
description Interview
name PD-Interview
ephone-dn  15
number 1010
label Ext. 1010
description Chief
name PD-Chief Garner
ephone-dn  16
number 1011
label Ext. 1011
description PTL Office
name PD-Patrol Office
ephone-dn  17
number 1012
label Ext. 1012
description PTL Desk
name PD-Patrol Desk
ephone-dn  18
number 1014
label Ext. 1014
description Substation
name PD-Substation
ephone-dn  19
number 1015
label Ext. 1015
description Garage
name PD-Garage
ephone-dn  20
number 1016
label Ext. 1016
description Lobby
name PD-Lobby
ephone-dn  21
number 1025
label 1025
name PD-Fax
ephone-dn  22
number 2025
label 2025
name TH-Fax
ephone-dn  23
number 2003
label Ext. 2003
description Upstairs
name TH-Upstairs
ephone-dn  24
number 7700
name Paging
paging
ephone  1
device-security-mode none
mac-address 0007.0E36.B838
type 7911
button  1:7 2o2,4
ephone  2
mac-address 0007.0E36.B876
type 7911
button  1:3
ephone  3
mac-address 0014.1C22.43A8
type 7905
button  1:5 2:2
ephone  4
mac-address 0015.2BD2.0817
type 7940
button  1:8 2o2,4
ephone  5
mac-address 0014.1C22.42B0
type 7905
button  1:19
ephone  6
mac-address 000F.90B0.CC29
type 7940
ephone  7
mac-address 0014.1CBC.E7E0
type 7905
button  1:17 2:2
ephone  8
mac-address 0014.1CBC.E7E2
type 7905
button  1:8 2o2,4
ephone  9
mac-address 0014.1CC3.C237
type 7905
button  1:23 2:4
ephone  10
mac-address 0016.46CB.47B8
type 7960
button  1:13 2:2
ephone  11
mac-address 0013.601C.1730
type 7960
button  1:1 2:2 3b4
ephone  12
mac-address 0013.194C.E675
type 7960
button  1:7 2:4 3:2
ephone  13
mac-address 0013.6090.A1C8
type 7960
button  1:15 2:2
line con 0
line aux 0
line vty 0 4
login
transport input telnet
ntp clock-period 17180681
ntp server 131.107.1.10
ntp server 198.110.48.12
end
Below is my config.  It appears to be trying.. But fails out with unknown extension...
! Last configuration change at 22:43:42 EDT Thu Sep 5 2013
! NVRAM config last updated at 22:38:47 EDT Thu Sep 5 2013
version 12.4
hostname PELIONCME-PD
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
voice-card 0
no dspfarm
voice service voip
sip
voice class codec 1
archive
log config
  hidekeys
no ip address
shutdown
duplex auto
speed auto
ip address 192.168.1.25 255.255.255.0
duplex full
speed auto
ip classless
ip http server
ip http path flash:
tftp-server SCCP11.9-3-1SR2-1S.loads
tftp-server flash:SCCP11.9-3-1SR2-1S
tftp-server flash:ringlist.xml
tftp-server CP7912080001SCCP051117A.sbin
tftp-server flash:Piano1.raw
tftp-server flash:Chime.raw
tftp-server flash:Sax1.raw
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Classic1.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring3.raw
tftp-server flash:cnu11.9-3
tftp-server flash:cnu11.9-3-1ES13.sbn
tftp-server flash:dsp11.9-3-1ES13.sbn
tftp-server flash:jar11sccp.9-3-1ES13.sbn
tftp-server flash:term11.default.loads
tftp-server app211.9-3-1ES13.sbn
tftp-server flash:apps11.9-3-1ES13.sbn
tftp-server SIP11.9-3-1SR2-1S.loads
tftp-server jar11sip.9-3-1ES13.sbn
tftp-server cvm11sip.9-3-1ES13.sbn
tftp-server apps11.9-0-3TH1-22.sbn
tftp-server cnu11.9-0-3TH1-22.sbn
tftp-server cvm11sccp.9-0-3TH1-22.sbn
tftp-server dsp11.9-0-3TH1-22.sbn
tftp-server jar11sccp.9-0-3TH1-22.sbn
tftp-server SCCP11.9-0-3S.loads
tftp-server flash:P00308000800.loads
tftp-server flash:P00308000800.sb2
tftp-server flash:P00308000800.sbn
tftp-server flash:P00308000800.txt
tftp-server P0030801SR02.loads
control-plane
voice-port 0/2/0
station-id name AnsMachine
station-id number 3024
caller-id enable
voice-port 0/2/1
station-id name FAX
station-id number 3025
caller-id enable
dial-peer voice 10 voip
description Connection to PoliceDept
destination-pattern 1...
session target ipv4:192.168.1.26
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 3024 pots
destination-pattern 3024
port 0/2/0
dial-peer voice 3025 pots
destination-pattern 3025
port 0/2/1
telephony-service
max-ephones 42
max-dn 144
ip source-address 192.168.1.25 port 2000
system message Pelion Town Hall
create cnf-files version-stamp 7960 Sep 05 2013 22:08:19
voicemail 8000
mwi relay
call-forward pattern 2...
call-forward pattern 1...
dn-webedit
time-webedit
transfer-pattern 1...
night-service code *88
ephone-dn  1
number 3001
name test1
ephone-dn  2
number 3002
name test2
ephone-dn  100
number 4510.... no-reg both
mwi on
ephone-dn  101
number 4511.... no-reg both
mwi off
ephone  1
type 7940
ephone  2
mac-address 000D.BC04.B218
type 7960
button  1:1 2:2
line con 0
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
password ##########
login
scheduler allocate 20000 1000
ntp clock-period 17180376
end
CME - with PSTN Connections...
Im pulling what little hair i have left out over this...
Building configuration...
Sep  6 03:34:29.084: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.1.139)
Current configuration : 8658 bytes
! Last configuration change at 23:34:29 EDT Thu Sep 5 2013
! NVRAM config last updated at 22:38:43 EDT Thu Sep 5 2013
version 12.4
hostname PELIONCME-PD-backup
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
voice service voip
sip
voice class codec 1
mode cme
max-dn 72
max-pool 24
create profile sync 0017433342341223
number 2025
voice translation-rule 1
rule 1 /^803\(.*\)/ /9\1/
rule 2 /\(..........\)/ /91\1/
voice translation-profile filter_803
translate calling 1
archive
log config
  hidekeys
no ip address
shutdown
duplex auto
speed auto
speed auto
full-duplex
ip http server
tftp-server ata030204sccp090202a.zup
tftp-server bass.raq
tftp-server bass.raw
tftp-server analog1.raw
tftp-server jamaica.raw
tftp-server pop.raw
tftp-server sax1,raw
tftp-server Klaxons.raw
tftp-server RingList.xml
tftp-server AreYouThere.raw
tftp-server asleep.raw
tftp-server CTU24raw.raw
tftp-server Curley.raw
tftp-server Drums1.raw
tftp-server AreYouThereF.raw
tftp-server NyukNyuk.raw
control-plane
voice-port 1/1/0
translation-profile incoming filter_803
caller-id enable
voice-port 1/1/1
ring number 3
caller-id enable
port 1/1/0
port 1/1/1
destination-pattern 3...$
session target ipv4:192.168.1.25
incoming called-number 1...$
codec g711ulaw
no vad
telephony-service
max-ephones 52
max-dn 208
call-forward pattern 3...
dn-webedit
transfer-pattern 3...
after-hours block pattern 1 1010 7-24
after-hours block pattern 2 1900 7-24
after-hours block pattern 3 011 7-24
create cnf-files version-stamp 7960 Sep 05 2013 23:17:08
ephone-dn  1
number 1005
label Ext. 1005
name PD-SGT J Elkin
ephone-dn  2
number 9712
label Police Main 9712
description 803-894-9712
name Police Main 9712
caller-id block
ephone-dn  3
number 1001
label Ext. 1001
ephone-dn  4
number 3535
label Town Hall Main 3535
description 803-894-3535
name Town Hall 3535
ephone-dn  5
number 1000
label Ext. 1000
ephone-dn  6
number 1002
label Ext. 1002
name PD-Evidence
ephone-dn  7
number 2001
label Ext. 2001
description Janice Poole
ephone-dn  8
number 2002
label Ext. 2002
description Rhona Gunter
name TH-Rhonda Gunter
ephone-dn  9
number 1003
label Ext. 1003
description ID Room
name PD-ID Room
ephone-dn  10
number 1004
label Ext. 1004
name PD-Supply Room
ephone-dn  11
number 1006
label Ext. 1006
name PD-Server Room
ephone-dn  12
number 1007
label Ext. 1007
description Kitchen
name PD-Kitchen
ephone-dn  13
number 1008
label Ext. 1008
description Capt M Crider
name PD-Capt M Crider
ephone-dn  14
number 1009
label Ext. 1009
name PD-Interview
ephone-dn  15
number 1010
label Ext. 1010
description Chief C Garner
ephone-dn  16
number 1011
label Ext. 1011
ephone-dn  17
number 1012
label Ext. 1012
name PD-Patrol Desk
ephone-dn  18
number 1014
label Ext. 1014
name PD-Substation
ephone-dn  19
number 1015
label Ext. 1015
description Garage
name PD-Garage
ephone-dn  20
number 1016
label Intercom
description Lobby Intercom
name Lobby Intercom
intercom 9712 label "Intercom"
ephone-dn  21
number 1025
label 1025
name PD-Fax
ephone-dn  22
number 2025
label 2025
name TH-Fax
ephone-dn  23
number 2003
label Ext. 2003
description Mayor
name TH-Mayor
ephone-dn  24
number 7700
name Paging
paging
ephone-dn  25
number 1116
label Lobby to All
description Lobby to All
name Lobby to All
ephone  1
type 7911
button  1:20
ephone  2
type 7960
ephone  3
type 7905
button  1:5 2:2
ephone  4
after-hour exempt
type 7940
button  1:16 2:2
ephone  10
type 7960
button  1:13 2:2
ephone  11
after-hour exempt
speed-dial 1 97852521 label "Central Dispatch"
type 7960
button  1:8 2:4 3:2
ephone  12
type 7960
button  1:7 2:4 3:2
ephone  13
type 7960
button  1:15 2:2
ephone  14
mac-address 0013.60B5.1FBE
type 7960
button  1:8 2:4 3:2
ephone-hunt 1 peer
pilot 4500
line con 0
line aux 0
line vty 0 4
ntp clock-period 17180675
end
jelkin001
I've tried so many different approaches to this.. Im pulling my hair out.
On debug .25 shows retries exceeded..
On debug .26 shows nothing...
nanosynth
I have done exactly what you want to do, so I attached the configs. CME-A would be at one site that had Cisco voip phones and analog phones on fxs ports. CME-B would be at the other site with Cisco voip phones and analog phones using the fxs cards. The CME-A is where I had the incoming pots lines from the telco terminating on FXO ports. Both CME-A and CME-B are 1760 routers. I also went one step further and added a 3rd 2620xm router that had the NM-CUE module in it only, just for voicemail.Of course this was in my lab, so my WAN was serial links. You could call from any phone to any phone and voicemail across the WAN. The hold music evev streamed across the WAN link properly.I used simple RIP as my routing protocol between CME's. Hopefully you can pull what you need from these configs.Also, the phones at CME-B site were assigned two of the incoming pots lines numbers from CME-A, just what you want to do i think.
Tracy Larson
Level 4
Level 4
Just took a quick glance at this stuff but do you need in your configs
voice service voip
   ip address trusted list
     ipv4 x.x.x.x x.x.x.x
on each side? I am no CME expert by any means so maybe this doesnt apply.
