10-30-2013 11:00 PM - edited 03-16-2019 08:10 PM
Hello everybody.
I have a network with two 2921 routers in it (K22.R1 and K22.R2), each router runs OSPF process with all networks that this router belongs to ncluding voice network), each have it's own CME (9.1), first CME works in VLAN 2 (10.10.22.1), second in VLAN 3 (10.20.22.1). IP phones inside each CME works fine, calls within each router are placed, but when phones from R1 call to R2 or vice versa, i see on the phone "unknown number", though all dial-peers are in place, and in debug I see that, for example, call from R1 is reaching R2, R2 matches incoming dial-peer, but it seems cannot find dial-peer for local registered phone.
I've modelled my network in PT (see in attached file), and in model it works fine, calls are reaching phones on remote router.
Here's portions of real configs:
! R1
interface GigabitEthernet0/0.2
description Voice VLAN 2
encapsulation dot1Q 2
ip address 10.10.22.1 255.255.255.0
interface GigabitEthernet0/1
description K22.R2
ip address 10.100.22.1 255.255.255.0
ephone-dn 1
number 2200
name Some Name
ephone 1
mac-address F41F.C267.8B98
type 7962
button 1:1
dial-peer voice 27 voip
destination-pattern 222.
session target ipv4:10.20.22.1
! R2
interface GigabitEthernet0/0.3
description Voice VLAN 3
encapsulation dot1Q 3
ip address 10.20.22.1 255.255.255.0
description K22.R1
ip address 10.100.22.2 255.255.255.0
ephone-dn 1
number 2220
name Some Name 1
ephone-dn 2
number 2221
name Some Name 2
ephone-dn 3
number 2222
name Some Name 3
ephone 1
mac-address 44AD.D9D5.182A
type 7962
button 1:1
ephone 2
mac-address 20BB.C092.47FF
type 7962
button 1:2
ephone 3
mac-address 5478.1AE1.1786
type 7962
button 1:3
destination-pattern 220.
session target ipv4:10.10.22.1
On the routers i see that all dial-peers are up, calls are reaching remote router, but it cannot find dial-peer and phone shows "Unknown Number".
K22.R1#sh dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE
27 voip up up 222. 0 syst ipv4:10.20.22.1
20005 pots up up 2200$ 0 50/0/1
K22.R1#ping 10.20.22.1
Sending 5, 100-byte ICMP Echos to 10.20.22.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
K22.R2#sh dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
27 voip up up 220. 0 syst ipv4:10.10.22.1
20004 pots up up 2220$ 0 50/0/1
20005 pots up up 2221$ 0 50/0/2
20006 pots up up 2222$ 0 50/0/3
K22.R2#ping 10.10.22.1
Sending 5, 100-byte ICMP Echos to 10.10.22.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
I've tried debugging ccapi, but i didn't see no problem in there. Where else can i look to find the problem?
Please help.
10-31-2013 12:11 AM
Just an assumption may be you need to enable caller-id under the dial-peer and ephone-dns
10-31-2013 08:44 AM
But how could it be connected to the dial-peer matching? I thought that caller-id is for cosmetic purposes, and calls are placed without caller-id info?
10-31-2013 08:43 AM
I keep thinking about it and here's the questions that i come to:
1: Should i configure voice codecs if i have two exactly similar routers and IP phones? Could it be a codec mismatch when call is done between routers?
2: in debug ccapi output on the router R1 that receiving the call from the phone registered on R2 i see a string
cisco-username=192.168.22.254
It's IP address configured on R2 GE 0/0 (on R1 GE 0/0 192.168.22.253 and they are in same VLAN 1). Why this IP appears as cisco-username and not 10.20.22.1 (CME source address)?
Tomorrow i'll post complete debug output of the calls.
10-31-2013 10:04 PM
I found it! It's a Toll Fraud prevention system!
Added to config
voice service voip
no ip address trusted authenticate
And that was it.
