11-06-2013 07:10 AM - edited 03-16-2019 08:15 PM
In planning our CUCM VM environment on UCS, I'm referencing Virtualization for Cisco Unified Communications Manager (CUCM)
For my subscriber nodes, the guidelines are straight forward. But how should I size my publisher and TFTP server? Same as subscribers, even though they have no phones registered?
Also, do customers generally purchase VMware from their Cisco partners? I wasn't sure if esxi was a Cisco part #, or we just use a standard vmware partner for that?
Bill
Solved! Go to Solution.
11-06-2013 08:10 AM
Hi Bill,
You can purchase VM Ware from your Cisco Partner which should also provide you with a ISV1 contract in which case Cisco will support any issues with the ESXi on the servers.
Otherwise Cisco wont support issues with VM Ware.
Jagpreet
11-06-2013 08:16 AM
You can have VMWare support you on ESXi, scroll down to the bottom
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-06-2013 07:43 AM
Yes, thumb rule is you use the same OVA for all nodes in the cluster.
java
11-06-2013 08:10 AM
Hi Bill,
Jagpreet
11-06-2013 08:16 AM
java
