02-13-2012 06:19 AM - edited 03-16-2019 09:33 AM
Hello All,
I have upgraded our Unity Connection from 7.1.3 to 8.5.1. The log file shows the upgrade has been completed. See the message below:
02/13/2012 03:05:49 upgrade_install.sh|Upgrade Complete -- (0)|<LVL::Info>
Successfully installed UCSInstall_UCOS_8.5.1.13900-5.sgn.iso
The system upgrade was successful. A switch version request has been submitted. This can take a long time depending on the platform and database size. Please continue to monitor the switchover process from the Cisco Unified Communications OS Platform CLI. Please verify the system restarts and the correct version is active.
After upgrade the output of the show version active and inactive is:
admin:show version active
Active Master Version: 7.1.3.10000-11
Active Version Installed Software Options:
ciscocm.refresh_upgrade_v1.0.cop
admin:
admin:
admin:show version inactive
Inactive Master Version:
Inactive Version Installed Software Options:
Here's what I see when I go to the OS admin page to swith the version manually:
Status
Informational Message Status: Ready
Installed Versions
Active Version 7.1.3.10000-11
Inactive Version 7.1.3.10000-11
Could you please let me know what am I doing wrong?
MK
02-13-2012 05:58 PM
This is the error I receive when I try to switch the version from CLI.
admin:utils system switch-version
If you are switching to an earlier release, you must run:
utils dbreplication reset all
from the publisher after all the nodes are switched over.
Do you really want to switch between versions ?
Enter (yes/no)? yes
Switching Version and Restarting the Appliance ...
Switch version duration can vary depending on the database size
and platform configuration. Please continue to monitor the
switchover process from here.
Waiting .................................................................................................
Operation failed
ERROR: Sync after switch version failed
admin:
02-13-2012 06:01 PM
Have you tried performing the upgrade again??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-13-2012 06:24 PM
Yes I have tried at least 5 times but everytime the same error. Is this a bug?
MK
02-14-2012 01:55 PM
Any help will be greately appriciated.
MK
02-14-2012 02:28 PM
Do you have any language localizations installed?
02-14-2012 02:30 PM
No I don't. Do I need to install any?
MK
02-14-2012 02:35 PM
No you don't. I recently had a similar failure with 8.6.1 to 8.6.2 upgrade and had to uninstall any locales first.
I notice you have "ciscocm.refresh_upgrade_v1.0.cop" installed. This file is only for upgrades to version 8.6 as the O/S also is upgraded. I'm not sure if that could be causing you a problem. If you did in fact install that, I would uninstall it and try your upgrade again.
02-14-2012 02:37 PM
How do I uninstall the "ciscocm.refresh_upgrade_v1.0.cop"?
MK
02-14-2012 03:07 PM
I did not know the answer to this until just now. I found the following post: https://supportforums.cisco.com/thread/2034456. If you have a contract, you might want to open a TAC case before taking any action to at least make sure I've even set you on the right path.
The only other idea I have is to actually upgrade to 8.6. I'm not sure your rationale for upgrading, but 8.5 was not good for my last installl due to severe issues with failover to the partner server and also outdial notification failures. 8.6 has been better. If you're interested, I can go on, but let me know your reasons, too.
Best of luck.
02-14-2012 03:16 PM
The only reason that I am going with 8.5 is because 8.6 is requiring an external 128GB USB device to be attached to the server. It's becasue of our current sever model and I am remote and have no physical access to the servers.
I guess my only option is to find a USB device and someone local to go and attach it.
Is there any way that I can force the installation without connecting the USB device? This is a lab environement.
MK
02-14-2012 03:24 PM
You've got me now. The docs also say you can use an external hard drive (USB) if you have that instead. I find myself wondering if the install will allow you to continue without saving messages/greetings or simply halt. Sorry I can't answer any further. I'll watch this post to see how you've faired.
02-14-2012 03:31 PM
Thanks for taking the time and replying to my post.
MK
02-14-2012 04:15 PM
Is this a standalone CUCM or CUCMBE??
Also, just our of curiosity, have you tried upgrading to something else?? let's say a 7.1(5) release and see if that works??
java
02-14-2012 08:01 PM
This is Unity Connection 7.1.3.
I tried to upgrade to 7.1.5 with the same error message. I think this is because I have installed "ciscocm.refresh_upgrade_v1.0.cop" .
MK
