UC on UCS
ichehouri
Level 2
Level 2
we purchased two UCS C210M2 and we want to install CUCM, unity connection and presence. The two UCS will be located in two different locations for redundancy so we will have cluster over the WAN for CUCM.
Can we have the same for unity connection so that the primary server will be in location A and secondary in location B (both locations are connected over the WAN)? note that we will have unified messaging (integration with exchange 2010) and the exchange server will only exist in location A.
also is there a UCS for unified communication course available? if yes please let me know some details (agends, location, schedule ...)
regards,
Ibrahim
Donald Jones
Ibrahim,
Depending on where you are located you can take a global knowledge class such as this one:
http://www.globalknowledge.com/training/course.asp?pageid=9&courseid=15722&catid=206&country=United+States
Yes you can cluster Connection over the WAN. Below are the requirements in order to do so:
Connection Cluster Requirements When the Servers Are in Separate Buildings or Sites
Revised July 27, 2010
Both servers must meet specifications according to the Cisco Unity Connection 8.x Supported Platforms List at http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html.
For a cluster with two physical servers, both must have the same platform overlay.
For a cluster with two virtual machines, both must have the same virtual platform overlay.
For a cluster with one physical and one virtual machine:
The  specifications for the physical server and the virtual machine should  match as closely as possible for available hard-disk space/vDisk space  and for RAM/vRAM.
When  the hard disks in the physical server and the virtual hard disks in the  virtual machine are not the same size, the smaller disks determine the  amount of disk space available for voice messages.
When  the number of users supported for the physical server and the virtual  machine do not match, only the smaller number of users is supported for  the cluster.
With  Platform Overlay 1 servers, you must add 2 GB of RAM to the physical  server so the amount of RAM in the physical server matches the 4 GB of  vRAM configured for Connection on the virtual machine.
Depending  on the number of voice messaging ports on each Connection server, the  path of connectivity must have the following guaranteed bandwidth with  no steady-state congestion:
For 50 voice messaging ports on each server—7 Mbps
For 100 voice messaging ports on each server—14 Mbps
For 150 voice messaging ports on each server—21 Mbps
For 200 voice messaging ports on each server—28 Mbps
For 250 voice messaging ports on each server—35 Mbps
Note The  bandwidth numbers above are intended as guidelines to ensure proper  operation of an active-active cluster with respect to synchronization  traffic between the two servers. Additional conditions such as network  congestion, CPU utilization, and message size may contribute to lower  throughput than expected. Call-control and call-quality requirements are  in addition to the guidelines above and should be calculated by using  the bandwidth recommendations in the applicable Cisco Unified Communications SRND at http://www.cisco.com/en/US/solutions/ns340/ns414/ns742/ns818/landing_uc_mgr.html.
The maximum round-trip latency must be no more than 150 ms.
The network must use the following load-balancing techniques for connections to the Connection servers:
The Connection servers are assigned a common DNS name with the Connection publisher server first.
All  user client and administrator sessions connect to the Connection  publisher server. If the Connection publisher server stops functioning,  the user client and administrator sessions must connect to the  Connection subscriber server.
Phone  systems must attempt to route incoming calls to the Connection  subscriber server. If no voice messaging ports are available to answer  calls on the Connection subscriber server, the phone systems must route  calls to the Connection publisher server.
The TCP and UDP ports of the firewall must be open as listed in the "IP Communications Required by Cisco Unity Connection 8.x" chapter of the Security Guide for Cisco Unity Connection at http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/security/guide/8xcucsecx.html.
Both Connection servers must have the same software and engineering-special versions installed.
Both Connection servers must have the same enabled features and configurations.
Both Connection servers must be configured to be in the same time zone.
Both Connection servers must connect to the same phone system(s).
If  the Connection servers contain dual NICs, the two NICs on each  Connection server must be configured for fault tolerance using a single  IP address, or one of the NICs must be disabled. Configuring the two  NICs with distinct IP addresses for network load balancing is not  supported.
For  selected servers supported for earlier versions of Connection, a memory  upgrade. To determine whether your server requires a memory upgrade,  see the applicable server-specific table in the Cisco Unity Connection 8.x Supported Platforms List.
For  selected servers supported for earlier versions of Connection,  replacement hard disks. To determine whether your server requires  hard-disk replacement, see the applicable server-specific table in the Cisco Unity Connection 8.x Supported Platforms List.
Don
Marwan ALshawi
Hi Ibrahim,
Have a look at the bellow link if you didnt, very useful for to read it for UC on UCS deployment
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Sizing_Guidelines
