12-09-2012 12:10 PM - edited 03-16-2019 02:37 PM
Hello All,
Apologies in advance for the long winded post. helping with the config woudl be awesome, but I'm not expecitng that and some concise links would be aprreciated.
I've been asked to setup a SIP trunk on the office UC540. Using CCA I thought it would not be a problem, but suffice it to say that when I applied the settings through CCA it broke a lot of stuff that one of the other guys had been doing through CLI - He has left so need to work out on my own.
In summary we have a SIP account with a provider and I've been doing a lot of reading but confusion has set in. Can anyone point me to a good CLI example of the following:
- Setup of SIP trunk
- Dial Peers. In summary I need to be able to press say 8....... to get a Line through SIP and 9...... to get a line through FXO
- An example of how to Map SIP DDI's to internal Extensions.
This is what I have from the Provider:
Number of Channels: 4
IP Address: 178.AA.42.156
SIP signalling gateway address: 88.BB.61.195
- UDP port 5060 egress/ingress to 88.BB.61.195 (IPDC SIP signalling gateways).
- All UDP ports between 6000 - 40000 egress/ingress to 88.BB.61.196 (IPDC Media gateway) Omission of this setting will result in one-way speech
DDI 02034478900- 02034478910
From what I can gather they haven't provided a Username/password and are authenticating my use of the service via my source IP so I assume something like as follows:
Internal Extensions are 2000-2100
voice translation-profile PROVIDER
translate calling 2010
translate called 2011
translate redirect-called 2011
dial-peer voice 888 voip
description SIP to Provider
translation-profile outgoing PROVIDER
preference 1
destination-pattern [8]...
rtp payload-type comfort-noise 13
session protocol sipv2
session target ipv4:88.BB.61.195
session transport udp
voice-class codec 2
dtmf-relay rtp-nte
fax-relay ecm disable
no vad
I assume I have to create a copy of above for every destination pattern that is present for the FXO to go out the SIP when preceeding 8 is pressed.
No idea on how to map the DDI's to an internal extension.
Am I missing anything?
I should also mention there is another SIP trunk to another UC520 over a VPN. This is what gets messed up when I use the CCA.
Thanks in advance
Dave
Solved! Go to Solution.
01-19-2013 12:00 PM
Ok..So you have some dsp resoruces, I will see if we can squeeze something out of it for this..
I need to go away for about 1hr...When I come back I will tell you the next things we will do..
It wont affect inbound calls to ordinary extension..but you need to configure your dial-peer from your provider and to your phones to use either g711alwa or g729
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
01-19-2013 01:08 PM
David,
Ok configure this...
sccp ccm group 1
associate profile 2 register softwareMTP
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions software 100
associate application SCCP
telephony-service
sdspfarm tag 2 softwareMTP
01-19-2013 01:10 PM
I forgot you also need to configure this...
dial-peer voice 3000 voip
codec g711alaw
Then do a test call for me again and send debug ccsip messages
and show sccp connection
01-19-2013 01:29 PM
01-19-2013 01:49 PM
Not sure if much help but see below diagram of setup
01-19-2013 02:02 PM
The MTP is in a shut down state..
configure this:
no shut
after you have done that..
Send me a "show sccp"
Then test again
send me the debugs
01-19-2013 02:10 PM
Sorry I did'd know I had to no shut it.
Dialed again and getting disconnect tone.
UC520London#
UC520London#sh sccp
SCCP Admin State: UP
Gateway Local Interface: Loopback0
IPv4 Address: 10.44.3.2
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.44.2.1, Port Number: 2000
Priority: N/A, Version: 4.0, Identifier: 1
Trustpoint: N/A
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.44.2.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 64, Reported Max OOS Streams: 0
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
UC520London#
UC520London#
044982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:02036678903@10.44.1.254;user=phone SIP/2.0
Max-Forwards: 69
Session-Expires: 3600;refresher=uac
Min-SE: 600
Supported: timer, 100rel
To: <02036678903>02036678903>
From: <07825372765>;tag=3567622128-43976207825372765>
P-Asserted-Identity: <07825372765>07825372765>
Call-ID: 2121383-3567622128-439754@MSX27.gammatelecom.com
CSeq: 1 INVITE
Allow: CANCEL, ACK, INVITE, BYE, OPTIONS, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK0b70409a195c42fa4f04b85b9df5249a
Contact: <07825372765>07825372765>
Content-Type: application/sdp
Accept: application/sdp
Content-Length: 290
v=0
o=MSX27 355458055228728827 1 IN IP4 88.215.61.195
s=sip call
c=IN IP4 88.215.61.196
t=0 0
m=audio 21216 RTP/AVP 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no;mr=0;mg=0;jmdelay=no;mrmods=
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
044983: //35828/A24D41A7B244/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 19 Jan 2013 22:08:48 gmt
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
044984: //35828/A24D41A7B244/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <02036678903>;tag=3F51C8A0-F4E02036678903>
CSeq: 1 INVITE
Reason: Q.850;cause=47
Content-Length: 0
044985: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:02036678903@10.121.30.4;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
P-Charging-Vector: icid-value=00001JQKoA;icid-generated-at=10.121.0.0;orig-ioi=tes001-tss-tra.gamma.uktel.org.uk
Content-Length: 0
044986: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <07825372765>;tag=3567622128-54545007825372765>
Call-ID: 2121384-3567622128-545441@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK89660c1be1f8b349ca133c8e0c917882
Content-Length: 290
v=0
o=MSX27 358638608674559765 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 21218 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
044987: //35831/A25C8358B24B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
044988: //35831/A25C8358B24B/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3F51C904-F4202036678903>
CSeq: 1 INVITE
Content-Length: 0
044989: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
044990: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <07825372765>;tag=3567622128-64361907825372765>
Call-ID: 2121385-3567622128-643612@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK09ab921560f7f7c106483f5c1d1dce8a
Content-Length: 291
v=0
o=MSX27 3588305549775032230 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 21220 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
044991: //35834/A26C61C9B252/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
044992: //35834/A26C61C9B252/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3F51C96C-1A4402036678903>
CSeq: 1 INVITE
Content-Length: 0
044993: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
044994: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <07825372765>;tag=3567622130-48107207825372765>
Call-ID: 2121386-3567622130-481064@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK68bea6d1ab9578fa2be06597f5a43728
Content-Length: 291
v=0
o=MSX27 8020201706511619257 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 21222 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
044995: //35837/A38352E2B259/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 19 Jan 2013 22:08:50 gmt
CSeq: 1 INVITE
Content-Length: 0
044996: //35837/A38352E2B259/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3F51D090-204102036678903>
CSeq: 1 INVITE
Content-Length: 0
044997: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
P-Charging-Vector: icid-value=00001msYr-;icid-generated-at=10.120.0.0;orig-ioi=tes001-tss-pst.gamma.uktel.org.uk
Content-Length: 0
044998: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <07825372765>;tag=3567622130-58120207825372765>
Call-ID: 2121387-3567622130-581194@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bKbe53d23ce3232a3a0a8337709740ee1b
Content-Length: 291
v=0
o=MSX27 8052300632320625016 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 21224 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
044999: //35840/A39469A3B260/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
045000: //35840/A39469A3B260/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3F51D100-3EB02036678903>
CSeq: 1 INVITE
Content-Length: 0
045001: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
045002: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <07825372765>;tag=3567622130-70249507825372765>
Call-ID: 2121388-3567622130-702488@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bKd955f0405d1bd6214dbabcf49c6d54ba
Content-Length: 291
v=0
o=MSX27 8018411111002326431 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 21226 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
045003: //35843/A3A9C614B267/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
045004: //35843/A3A9C614B267/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3F51D190-253F02036678903>
CSeq: 1 INVITE
Content-Length: 0
045005: //35843/A3A9C614B267/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
045006: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
045007: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <07825372765>;tag=3567622133-17012607825372765>
Call-ID: 2121389-3567622133-170119@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bKe072e6590ee3eb8c1b4e6e93b2b90a8b
Content-Length: 289
v=0
o=MSX27 80181301111256727 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 21228 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
045008: //35846/A51EB6F1B26E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 19 Jan 2013 22:08:53 gmt
CSeq: 1 INVITE
Content-Length: 0
045009: //35846/A51EB6F1B26E/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3F51DB18-1A7802036678903>
CSeq: 1 INVITE
Content-Length: 0
045010: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
P-Charging-Vector: icid-value=00001msYrV;icid-generated-at=10.120.0.0;orig-ioi=tes001-tss-pst.gamma.uktel.org.uk
Content-Length: 0
045011: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <07825372765>;tag=3567622133-28897407825372765>
Call-ID: 2121390-3567622133-288967@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bK1cdb2eae0e2210c668257623fcf698ef
Content-Length: 291
v=0
o=MSX27 8020410203381330601 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 21230 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
045012: //35849/A5310734B275/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
045013: //35849/A5310734B275/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3F51DB94-102802036678903>
CSeq: 1 INVITE
Content-Length: 0
045014: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
045015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 69
Min-SE: 600
From: <07825372765>;tag=3567622133-39985007825372765>
Call-ID: 2121391-3567622133-399841@MSX27.gammatelecom.com
CSeq: 1 INVITE
Via: SIP/2.0/UDP 88.215.61.195:5060;branch=z9hG4bKa2997156d480d64e0a455c394f25799d
Content-Length: 290
v=0
o=MSX27 805283639002410566 1 IN IP4 88.215.61.195
s=sip call
t=0 0
m=audio 21232 RTP/AVP 8 18 101
a=fmtp:101 0-15
a=sendrecv
045016: //35852/A543F305B27C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
045017: //35852/A543F305B27C/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <02036678903>;tag=3F51DC10-87702036678903>
CSeq: 1 INVITE
Content-Length: 0
045018: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
01-19-2013 02:30 PM
The MTP is not showing as registered. Its not even showing at all..Can you try this..
dspfarm profile 1 conference
shutdown
no maximum sessions software 100
maximum sessions hardware 2
no shut
Then do a show sccp again..This is just to test
If you see mtp registered, do another test call...
01-19-2013 02:39 PM
Looks like its up but still get disconnect tone inbound
UC520London#sh sccp
Port Number: 2000
IP Precedence: 5
Trustpoint: N/A
MTP Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 4, Reported Max OOS Streams: 0
TLS : ENABLED
UC520London#
01-19-2013 02:41 PM
tried to restart DSPprofile 1 and got this
UC520London(config)#dspfarm profile 1 conference
UC520London(config-dspfarm-profile)#no shut
Enabling profile failed due to insufficient CONFERENCING resources,
resources available to support 0 sessions; please modify the
configuration and retry
01-19-2013 03:08 PM
I think I'm going to do this another way. Rather than have a SIP trunk DID going to the Auto Attendant I'll make the PSTN POTS line the auto attendant number. That negates the MTP requirement I believe.
Therefore I really just need to be able to get a SIP DID to ring an extension. Unfortunately I'm not onsite so can't really test with a handset.
I really appreciate your help on this and can I ask 1 more favour? Can you look at my config and tell me if there is anything I'm missing or should alter if I wanted to have the SIP number 02036678903 ring extension 2800? I just need the ability to receive a call from the SIP trunk and answer on a handset.
If I can achieve that then I might have a workable setup.
Thanks in advance
Dave
01-19-2013 06:41 PM
To get this number to ring on extension 2800..
You need to change this config as follows..
voice translation-rule 4
rule 1 /^02036678903/ /2800/
Leave this dial-peer as it is..
description DDIRange
translation-profile incoming DDIRange_Called_4
session target sip-server
incoming called-number 02036678903
dtmf-relay rtp-nte
codec g711alaw
no vad
By the way try and send me the logs when the MTP was active. Send debug ccsip messages
To enable your ocnference profile back, you need to disable the MTP
shut
01-20-2013 02:09 AM
Thanks I'll try that and update the thread with new logs shortly.
01-23-2013 01:38 PM
Hello aokanlawon,
Mate you are awesome for helping me out. As a result of your help I managed to at least get the DDI range working to the internal extensions.
I'm going to have a play with the AutoAttendant and will post logs if I hit issues.
Thanks for your help.You are the man!!!
Dave
02-04-2013 11:23 AM
Hello aokanlawon or communitee,
Sorry to bring this thread up again but its somewhat related and I though you may have seen it before. Can you advise why my SIP DDI's wont forward? Basically a extension with a SIP DDI is put on forward the call wont connect. I can see it forwarding in the CCSIP messages to the desintation number. When the forward is not present the call goes throguh to the original desination without issue.
I setup the following scenario
Currently 2805 forwarded to 2810
rule 1 /^02070787756/ /2805/
ephone-dn 80 octo-line
number 2805 no-reg primary
label HouseManager
description HouseMgr 2805
name House Manager
mobility
call-forward all 2810
When Call comes in on DDI 02070787756 I can see the SIP messages translation to 2810. But then it says service unavailable.
I tried enabiling the MTP as per our attempts above thinking I may need to proxy the call but this made no difference.
codec g711ulaw
David
