03-23-2019 06:31 PM
Can I install a CP-7841 phone on a UC540W? I actually bought both and the phone is constantly showing "Unprovisioned" on it. Thanks
03-23-2019 11:22 PM
03-24-2019 05:11 PM
You bought an obsolete system, the UC5xx are past their EOS/EOL date, the last CME release they received was 8.1 or 8.2, while at the same time buying a current device which was never tested or supported on those releases.
7841 needs CME 10.0 as minimum to work
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
You need to either buy old devices which are compatible with the old CME release you have on the UC5xx, or to buy a newer ISR which supports a CME release that has the 7841 included.
