03-23-2019 10:27 PM
I have the following conditions.
I need to achieve the following .
03-23-2019 11:12 PM - edited 03-23-2019 11:17 PM
You can create Route Group say RG_SIP in which you put the SIP Trunk to PBX, Create another Route Group with Two local MGCP GW. Create Route List and Put RG_SIP and MGCP Route Group. Use this in Route Patterns
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
03-24-2019 05:13 PM
03-24-2019 06:27 PM
Make sure you use OOB options 'ping' on your sip trunk in cucm, so that if it goes out of service, it can successfully fail over to your mgcp gateway
