12-27-2012 06:02 AM 03-16-2019 02:53 PM 更新
Gang,
I have a strange issue that I need help with. I have a UC560 installed with (5) Centrex lines from the carrier. When an outside call comes in the following happens:
1. The phone (7962) rings with the caller ID displayed.
2. After approx 3 seconds of ringing the phone stops ringing and the display goes blank as if the call was dropped. However, on the calling party phone the call continues to ring.
3. After another 5 seconds the 7962 phone in the office starts ringing again and you can answer the call as you normally would. The caller ID is gone though and the display just shows "Unknown Caller".
My guess is that the caller ID information being sent from the carrier is somehow changed after the first few seconds of the ringing. This is causing the UC560 to reinitialize the call setup I think.
I was able to workaround this issue by setting "caller-id alerting ring 2" but this delays the call from coming in and customers are complaining it takes too long for someone to answer.
My next step is to call the carrier and see if this is something they have configured on their end.
Has anyone seen this before?
-mike
解決済! 解決策の投稿を見る。
12-27-2012 06:40 AM
Possibly a long pause between rings makes the system believe the call hasended before answering. Then when rings resume again, it is treated as a new call, but caller-id information is lost. To confirm that you can take "debug vppm signal" with :term mon". In that case do not enable other debugs, and do not use attachments to post.
Indipendetnly from the above, you can configure 'immediate' in plar command to have phones ring immediately without waiting for caller-id. However with that setting if the call is answered before caller0id is displayed, then caller-id will not show.
Aslo recommended, update UC500 software and check again.
12-27-2012 07:36 AM
Like Paolo mentioned try the following under the fxo ports:
connectin plar opx "extension number"
12-27-2012 09:56 AM
Paolo,
Thanks for the input. There is no long pause between rings from the calling party end. If I connect an analog phone to the POTS line the call rings as expected. The pause between rings is only from the UC560 to the IP phone. It looks like typical caller ID information is sent around 1.5 to 2 rings:
"Before Cisco IOS Release 12.4(11)XW, Foreign Exchange Office (FXO) Caller ID in North America was delivered between the first and second ring cycles based on the GR-30-CORE standard. FXO software was configured to wait for Caller ID delivery before initiating the call setup for the next leg. As a result, the destination endpoint did not start ringing until after 1.5 to 2 ring cycles on the FXO port."
I think the UC560 may be answering before all of the caller ID information is passed. Does anyone know if "line reversal" caller ID delivery would cause something like this? Or if the the UC560 treats Single Data Message Format (SDMF) or Multiple Data Message Format (MDMF) differently?
I am going to try the immediate plar config and see if that makes a difference as well as capture some vppm signal debug. I have to wait until the office closes today first though. I'll report back later.
-mike
12-27-2012 03:23 PM
Paolo,
Here is the output of my capture tonight.
First, I removed the caller-id 2 ring setting:
voice-port 0/1/0
no caller-id alerting ring 2
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
Then I made a test call into the POTS line and the timeline below is what happened. Times are approximate as it was difficult to see the exact time in the log when the ringing started/stopped.
23:11:28 Called phone (ext 60) ringing
23:11:34 Called phone stops ringing, calling phone still hears ringing
23:11:46 Called phone starts ringing again, calling phone still hears ringing
031990: Dec 27 23:11:26.111: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
031991: Dec 27 23:11:26.111: htsp_timer - 125 msec
031992: Dec 27 23:11:26.239: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
031993: Dec 27 23:11:26.239: htsp_timer - 10000 msec
031994: Dec 27 23:11:26.239: htsp_timer3 - 5600 msec
031995: Dec 27 23:11:26.239: [0/1/0] htsp_start_caller_id_rx:BELLCORE
031996: Dec 27 23:11:26.239: htsp_start_caller_id_rx create dsp_stream_manager
031997: Dec 27 23:11:26.239: [0/1/0] htsp_dsm_create_success returns 1
031998: Dec 27 23:11:28.187: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
031999: Dec 27 23:11:28.187: fxols_ringing_not
032000: Dec 27 23:11:28.187: htsp_timer_stop
032001: Dec 27 23:11:28.187: htsp_timer - 10000 msec
032002: Dec 27 23:11:29.499: [0/1/0] htsp_dsm_feature_notify_cb returns 2 id=DSM_FEATURE_SM_CALLERID_RX
032003: Dec 27 23:11:29.499: htsp_process_event: [0/1/0, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
032004: Dec 27 23:11:29.499: htsp_timer_stop
032005: Dec 27 23:11:29.499: htsp_timer_stop3
032006: Dec 27 23:11:29.499: [0/1/0] htsp_stop_caller_id_rx. message length 176htsp_setup_ind
032007: Dec 27 23:11:29.499: [0/1/0] get_fxo_caller_id:Caller ID received. Message type=128 length=42 checksum=4A
032008: Dec 27 23:11:29.499: [0/1/0] Caller ID String 80 27 01 08 31 32 32 37 31 38 31 31 02 0A 37 38 31 35 33 30 38 31 39 32 07 0F 57 49 52 45 4C 45 53 53 20 43 41 4C 4C 45 52 4A
032009: Dec 27 23:11:29.499: [0/1/0] get_fxo_caller_id calling num=781XXXXXXX calling name=WIRELESS CALLER calling time=12/27 18:11
032010: Dec 27 23:11:29.499: fxols_callerid_done: call being answered
032011: Dec 27 23:11:29.503: [0/1/0] htsp_dsm_close_done
032012: Dec 27 23:11:29.503: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
032013: Dec 27 23:11:29.503: fxols_wait_setup_ack:
032014: Dec 27 23:11:29.503: htsp_timer - 6000 msec
032015: Dec 27 23:11:29.507: htsp_timer_stop3
032016: Dec 27 23:11:29.507: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_prochtsp_setup_req
032017: Dec 27 23:11:29.507: htsp_process_event: [50/0/571.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
032018: Dec 27 23:11:29.507: htsp_ephone_start_caller_id_tx calling num=781XXXXXXX calling name =WIRELESS CALLER called num=60 orig called num=
032019: Dec 27 23:11:29.507: [50/0/571.1] set signal state = 0x0 timestamp = 0
032020: Dec 27 23:11:29.511: efxs_onhook_setup: local target is available
htsp_alerthtsp_alert_notify
032021: Dec 27 23:11:29.519: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
032022: Dec 27 23:11:29.587: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0110]fxols_rvs_battery
032023: Dec 27 23:11:29.587: htsp_timer_stop2
032024: Dec 27 23:11:29.587: htsp_timer_stop2
032025: Dec 27 23:11:32.107: htsp_process_event: [0/1/0, FXOLS_PROCEED_RVS_BT, E_DSP_SIG_0000]
032026: Dec 27 23:11:34.227: htsp_process_event: [0/1/0, FXOLS_PROCEED_RVS_BT, E_DSP_SIG_0100]fxols_disc_confirm
032027: Dec 27 23:11:34.227: htsp_timer_stop
032028: Dec 27 23:11:34.227: htsp_timer_stop2
032029: Dec 27 23:11:34.227: htsp_timer_stop3
032030: Dec 27 23:11:34.227: htsp_timer_stop3
032031: Dec 27 23:11:34.231: htsp_process_event: [50/0/571.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
032032: Dec 27 23:11:34.231: [50/0/571.1] set signal state = 0x4 timestamp = 0
032033: Dec 27 23:11:34.231: htsp_process_event: [0/1/0, FXOLS_PROCEED_RVS_BT, E_HTSP_RELEASE_REQ]fxols_offhook_release
032034: Dec 27 23:11:34.231: htsp_timer_stop
032035: Dec 27 23:11:34.231: htsp_timer_stop2
032036: Dec 27 23:11:34.231: htsp_timer_stop3
032037: Dec 27 23:11:34.231: [0/1/0] set signal state = 0x4 timestamp = 0
032038: Dec 27 23:11:34.231: htsp_timer - 2000 msec
032043: Dec 27 23:11:36.231: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
032044: Dec 27 23:11:36.231: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
032045: Dec 27 23:11:38.107: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
032046: Dec 27 23:11:38.107: htsp_timer - 125 msec
032047: Dec 27 23:11:38.235: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
032048: Dec 27 23:11:38.235: htsp_timer - 10000 msec
032049: Dec 27 23:11:38.235: htsp_timer3 - 5600 msec
032050: Dec 27 23:11:38.235: [0/1/0] htsp_start_caller_id_rx:BELLCORE
032051: Dec 27 23:11:38.235: htsp_start_caller_id_rx create dsp_stream_manager
032052: Dec 27 23:11:38.235: [0/1/0] htsp_dsm_create_success returns 1
032053: Dec 27 23:11:40.227: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
032054: Dec 27 23:11:40.227: fxols_ringing_not
032055: Dec 27 23:11:40.227: htsp_timer_stop
032056: Dec 27 23:11:40.227: htsp_timer - 10000 msec
032057: Dec 27 23:11:43.836: htsp_process_event: [0/1/0, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
032058: Dec 27 23:11:43.836: htsp_timer_stop3
032059: Dec 27 23:11:44.108: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0000]
032060: Dec 27 23:11:46.228: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
032061: Dec 27 23:11:46.228: fxols_ringing_not
032062: Dec 27 23:11:46.228: htsp_timer_stop
032063: Dec 27 23:11:46.228: htsp_timer_stop3
032064: Dec 27 23:11:46.228: [0/1/0] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
032065: Dec 27 23:11:46.228: [0/1/0] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data.
032066: Dec 27 23:11:46.228: [0/1/0] get_local_station_id calling num= calling name= calling time=12/27 18:11 orig called=
032067: Dec 27 23:11:46.228: [0/1/0] htsp_dsm_close_done
032068: Dec 27 23:11:46.228: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
032069: Dec 27 23:11:46.228: fxols_wait_setup_ack:
032070: Dec 27 23:11:46.228: htsp_timer - 6000 msec
032071: Dec 27 23:11:46.232: htsp_timer_stop3
032072: Dec 27 23:11:46.232: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_prochtsp_setup_req
032073: Dec 27 23:11:46.236: htsp_process_event: [50/0/571.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
032074: Dec 27 23:11:46.236: htsp_ephone_start_caller_id_tx calling num= calling name = called num=60 orig called num=
032075: Dec 27 23:11:46.236: [50/0/571.1] set signal state = 0x0 timestamp = 0
032076: Dec 27 23:11:46.236: efxs_onhook_setup: local target is available
032077: Dec 27 23:11:46.248: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
032079: Dec 27 23:11:50.108: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
032080: Dec 27 23:11:50.108: htsp_timer_stop
032081: Dec 27 23:11:50.108: htsp_timer_stop2
032082: Dec 27 23:11:52.228: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
032083: Dec 27 23:11:52.228: htsp_timer_stop2
032084: Dec 27 23:11:52.228: htsp_timer - 6000 msec
032085: Dec 27 23:11:58.228: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER]fxols_disc_confirm
032086: Dec 27 23:11:58.228: htsp_timer_stop
032087: Dec 27 23:11:58.228: htsp_timer_stop2
032088: Dec 27 23:11:58.228: htsp_timer_stop3
032089: Dec 27 23:11:58.228: htsp_timer_stop3
032090: Dec 27 23:11:58.228: htsp_process_event: [50/0/571.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
032091: Dec 27 23:11:58.228: [50/0/571.1] set signal state = 0x4 timestamp = 0
032092: Dec 27 23:11:58.232: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
032093: Dec 27 23:11:58.232: htsp_timer_stop
032094: Dec 27 23:11:58.232: htsp_timer_stop2
032095: Dec 27 23:11:58.232: htsp_timer_stop3
032096: Dec 27 23:11:58.232: [0/1/0] set signal state = 0x4 timestamp = 0
032097: Dec 27 23:11:58.232: htsp_timer - 2000 msec
032102: Dec 27 23:12:00.232: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
032103: Dec 27 23:12:00.232: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
12-28-2012 04:01 AM
can you try under voice port
no battery-reversal
12-28-2012 04:25 AM
Paolo,
no battery-reversal did the trick! Now I can call the main number and there is no interruption in the ringing of the IP phone. Thanks very much.
-mike
12-28-2012 04:27 AM
Thank you for the nice rating and good luck!
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
