04-29-2011 01:43 PM - edited 03-16-2019 04:44 AM
I've been having problems getting our UC560 licenses installed. I finally managed to get them installed and now the system just shows 16 Evaluation licenses and 0 Permenant licenses.
The way I understand it, there should be 16 built in licenses plus the 16 that I installed. So, I should see 32 permenant licenses, right?
If I try to install the licenses again it says that they are already installed. How do I get it to show my 32 permenant licenses?
- Marc
Solved! Go to Solution.
04-30-2011 12:52 AM
If you think you have done everything right, but the result is not the one expected, contact licensing@cisco.com
04-30-2011 12:52 AM
05-04-2011 11:16 AM
Thanks Paolo. Cisco licensing connected in and ran some commands that made it show up correctly!
- Marc
05-04-2011 11:39 AM
Thank you for the nice rating and good luck!
