UC560 password recovery
finetecinc
I'm new to UC560. please help with the following:
1. from CLI, entered "enable" and password got "bad secrets"
2. from Configuration Assistant, the UC560 displayed "unreachable: authorization failed"
fkarami
Hi David,
Here is a link that would explain how you can reset the password on the UC560 or any 1800, 2800 or 2600 series router.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
Hope this helps.
Cheers,
Farbod
Hi:
Thanks for information, however, it didn't work for me. I am using serial port with Putty and when press Brk key or even Ctrl + Brk keys during boot up screen is blank. No prompt at all comes up.
Any other suggestions? By the way my unit is UC560.
Hermann
