UCCE Peripheral Gateway show slurpd error (ICM version 7.x)
Sarg .
Level 3
Level 3
Hello Team,
I just logged into my PG1 and I noticed the attached error messages. Can I ask if anyone has seen these errors before? Please see the attachments.  I am running legacy  ICM 7.x with CAD.
Manish Gogna
You can try the following:
Stop LDAP Monitor Service  - Browse to ..\Desktop\log\replica folder - Delete all files in
the folder  - Start LDAP Monitor service
Then reboot PG and see if it helps.
Manish
thank you , i will definitely try this but could you please tell me what those steps do in the background and if I hit an issue, can you give me a summary of roll-back process
slurpd is the replication process for the onboard LDAP, as the error is related to this service so we are trying to reinitialized LDAP.
Manish
the only thing i can find in that folder directory is a replication logs and nothing else
