UCCX - Active Directory Appadmin User Mapping
gpsriramdc
Level 4
Level 4
Hi All,
We have CUCM 8.6 & UCCX 8.5 . Now UCCX using the  CUCM Local Endusers. We have the plan to integrate the CUCM with Active Directory.
What is the procedure to configure the UCCX Appadmin username after the AD  integrate ? What are other points to be considered becuase of this integration.
Thanks in Advance
Anas Abueideh
Level 9
Level 9
for UCCX you need only to create uccx appadmin in LDAP users. we need this because after integration all local enduser will be removed.
you need to create a username in LDAP which has access to the OU that your useres located. users which have last names will be synched.
Anas
please rate if it is helpful
Ayodeji Okanlawon
The uccxappadmin username is not sycned with LDAP. It is a local account and is not affected by your LDAP integration. It is only end users that are synced with AD.
Please look at this thread for a detailed answer.. Everythiung you need is in there.
https://supportforums.cisco.com/thread/2159285
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
