UCCX application user and password.
waqas sardar
Hi Team ,
Is there any effect on configuration if i change username and password by using these commands?
utils reset_application_ui_administrator_name
utils reset_application_ui_administrator_password
Actually i don't know the username and password of application user of uccx even not in the cucm enduser.
8 Replies 8
Brandon Pierce
Level 4
Level 4
The administrator name and password is just the end user to log into the system.  The only thing that is going to affect is the initial login to the services and administration.  The OS admin and DRS will not be affected.
Server is in production . If services will effect then its can effects to IVR or agents?
Hi.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_5/configuration/guide/uccx851cli.pdf
The above Cli reference reports the following command as available:
set uccx appadmin administrator userXXX
where userXXX is a CUCM existing end user.
Please post the output of a "show version active" of your UCCX
Carlo
Please rate all helpful posts "The more you help the more you learn"
admin:show version active
Active Master Version: 8.5.1.10000-37
Active Version Installed Software Options:
No Installed Software Options Found.
Hi Carlo,
Any finding ?
Hi.
Try this query if it can help you
run sql select name from applicationuser
Carlo
Hi.
Because UCCX application administrator users are synced from CUCM,
you can issue command show uccx appadmin administrators on your UCCX server than go into CUCM and , if needed, change password there.
Carlo
show uccx appadmin administrators command is not available on 8.5.1 version ?
admin:show uccx
      show uccx cad*
      show uccx components
      show uccx dbcontents
      show uccx dbschema
      show uccx dbserver*
      show uccx dbtable*
      show uccx jtapi_client*
      show uccx license
      show uccx provider*
      show uccx recordings*
      show uccx servm*
      show uccx subcomponents
      show uccx tech*
      show uccx trace*
      show uccx version
admin:set uccx
      set uccx cad*
      set uccx provider*
      set uccx trace*
