02-24-2013 09:26 AM - edited 03-16-2019 03:54 PM
I have UCCX 8.0.2.11005-20 and CUCM 8.0.3.20000-2 running on ESXI 4.1. bottom line is the uccx engine service would not start. If I restart the server I see manager manager go into inservice status and subsystem manager to partial service and that is as close as I get. Needless to say route point/port shows unknown is cucm. However the data check in cucm is good and jtapi reports good as well in uccx. I will appreciate any suggestions.
Cisco JTAPI Client
Node ID: 1 -- Cisco JTAPI Client versions are consistent
Unified CM Telephony Users
uccx_1 -- Ok
Unified CM Telephony Port Groups
Port Group 0
CTI ports on node 1 -- Ok
CCM Data
Location-- Ok
Media Resource Group List-- Ok
User Hold Audio Source-- Ok
Require DTMF Reception-- Ok
Alerting Name Ascii-- Ok
Device Pool--Ok
Partition-- Ok
Calling Search Space-- Ok
VoiceMailProfile-- Ok
AAR Group-- Ok
NetWork Hold Audio Source-- Ok
CallPickUpGroup-- Ok
PresenceGroup-- Ok
Unified CM Telephony Triggers
icd
icd -- Ok
CCM Data
Device Pool-- Ok
Partition-- Ok
Location-- Ok
Forward Busy Calling Search Space-- Ok
PresenceGroup-- Ok
02-24-2013 10:42 AM
You need to pull the MIVR logs from UCCX and look for description of why it is failing, the log is pretty good for troubleshooting this type of an issue.
HTH,
Chris
02-24-2013 06:56 PM
02-25-2013 01:15 PM
This is the most evident source of the problem. Does anyone have any ideas on how to address this ?
Received request to start the service Cisco Unified CCX Engine
2002-02-28 20:07:37 :INFO: Checking if PID File exists.
2002-02-28 20:07:37 :INFO: process Cisco Unified CCX Engine is not running
2002-02-28 20:07:37 :INFO: Starting process Cisco Unified CCX Engine, Exe=/opt/cisco/uccx/bin/UCCX_Engine, Conf=/opt/cisco/uccx/conf/UCCX_EngineCfg.xml
2002-02-28 20:07:37 :INFO: Cisco Unified CCX Engine initialization complete.... PID 17216 updated in pid file /opt/cisco/uccx/conf/UCCX_Engine.pid
2002-02-28 20:10:08 :INFO: Received request to stop the service Cisco Unified CCX Engine
2002-02-28 20:10:08 :INFO: PID File exists, pid=17216
2002-02-28 20:10:08 :INFO: Stopping the Process Cisco Unified CCX Engine, pid=17216
2002-02-28 20:10:08 :INFO: Stop error for PID 17216 : No such process
2002-02-28 20:10:08 :INFO: process Cisco Unified CCX Engine with PID 17216 might have crashed
2002-02-28 20:10:08 :INFO: Received request to start the service Cisco Unified CCX Engine
2002-02-28 20:10:08 :INFO: Checking if PID File exists.
2002-02-28 20:10:08 :INFO: process Cisco Unified CCX Engine is not running
2002-02-28 20:10:08 :INFO: Starting process Cisco Unified CCX Engine, Exe=/opt/cisco/uccx/bin/UCCX_Engine, Conf=/opt/cisco/uccx/conf/UCCX_EngineCfg.xml
2002-02-28 20:10:08 :INFO: Cisco Unified CCX Engine initialization complete.... PID 25401 updated in pid file /opt/cisco/uccx/conf/UCCX_Engine.pid
2002-02-28 20:11:18 :INFO: Received request to stop the service Cisco Unified CCX Engine
2002-02-28 20:11:18 :INFO: PID File exists, pid=25401
2002-02-28 20:11:18 :INFO: Stopping the Process Cisco Unified CCX Engine, pid=25401
2002-02-28 20:11:18 :INFO: Stop error for PID 25401 : No such process
2002-02-28 20:11:18 :INFO: process Cisco Unified CCX Engine with PID 25401 might have crashed
2002-02-28 20:11:18 :INFO: Received request to start the service Cisco Unified CCX Engine
2002-02-28 20:11:18 :INFO: Checking if PID File exists.
2002-02-28 20:11:18 :INFO: process Cisco Unified CCX Engine is not running
2002-02-28 20:11:18 :INFO: Starting process Cisco Unified CCX Engine, Exe=/opt/cisco/uccx/bin/UCCX_Engine, Conf=/opt/cisco/uccx/conf/UCCX_EngineCfg.xml
2002-02-28 20:11:18 :INFO: Cisco Unified CCX Engine initialization complete.... PID 25984 updated in pid file /opt/cisco/uccx/conf/UCCX_Engine.pid
2002-02-28 20:12:30 :INFO: Received request to stop the service Cisco Unified CCX Engine
2002-02-28 20:12:30 :INFO: PID File exists, pid=25984
2002-02-28 20:12:30 :INFO: Stopping the Process Cisco Unified CCX Engine, pid=25984
2002-02-28 20:12:30 :INFO: Stop error for PID 25984 : No such process
2002-02-28 20:12:30 :INFO: process Cisco Unified CCX Engine with PID 25984 might have crashed
2002-02-28 20:12:31 :INFO: Received request to start the service Cisco Unified CCX Engine
2002-02-28 20:12:31 :INFO: Checking if PID File exists.
2002-02-28 20:12:31 :INFO: process Cisco Unified CCX Engine is not running
03-05-2013 09:29 AM
I think there is an issue with UCCX8.0.2 on ESXI 4.1 on AMD Opteron hardware. As a workaround I installed UCCX8.0.2 on vmware workstation on an intel based laptop and all services are in inservice and cti ports and RP are registered.
03-05-2013 09:31 AM
So, I take it this is a lab environment?
AMD based processors have been known to cause issues with the Cisco apps.
HTH,
Chris
