UCCX - Send Busy Here (486) to PSTN from CSQ
York1975
New member here so please excuse any lack of knowledge.
I'm looking to see how you can send a Busy Here (486) SIP signal back to the PSTN from a CSQ at a determined number of calls inbound?
For example, I need a busy here signal on a CSQ when 16 agents are busy and then the CSQ to be ready again when agents become available.
Any help is appreciated.
HARIS_HUSSAIN
1) You can post your UCCX related queries in UCCX Section here.
https://community.cisco.com/t5/contact-center/bd-p/5926-discussions-contact-center
2) For your solution, when each call is queued you have to check the Number of calls in Waiting and based on that play a prompt "we are busy here"  OR " Drop Call" OR " Transfer Call to Translation patter with will Reject call with Busy Reason code.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
