05-19-2013 01:53 AM - edited 03-16-2019 05:24 PM
HI
we having following server
1. Call Manager Cluster (Publisher & Subscriber)
2. Voice Mail System (Unity server)
3. UCCX Server
can any one guide how to integrate uccx with call manger cluster.
05-19-2013 02:38 AM
Hi Syed,
You can refer this POST for integration of UCCX with CUCM.
https://supportforums.cisco.com/docs/DOC-22951
regds,
aman
05-19-2013 02:38 AM
you must ceate an AXL application user user in CUCM for the UCCX the user must has (Standard AXL API Access), then you can follow the steps in the folowing link,
by this you have the integration between the CUCM and the UCCX, then you must configure the Application and
associate it with trigger (CTI Route Point), and create Resource groupe ....etc, this configuration done in UCCX and by using the AXL user this configuration will relicated to CUCM.
