04-07-2013 10:32 AM - edited 03-16-2019 04:39 PM
Hello Team,
What is the differents between UCM 7825 node and IME 7825 node in BOQ it is an license or server.please check
Thnaks & Regards
Solved! Go to Solution.
04-08-2013 06:21 AM
Are you planning on integrating directly to another company bypassing PSTN and using IME/ASA for calls?
This is not a widely deployed solution and the percentage of customers using it is very, very low ( I wish I had some numbers to back it up). Since it is free Cisco bundles it with all deals, but unless you have plans on deploying it you will not need it. 2 servers for CUCM would be sufficient if they are both at the same data center and if your total number of devices is ~1000 or less. If you have not purchased the MCS servers yet, you might want to check with reseller if they are still available as Cisco inventory might have ran out and IBM no longer makes those specs.
HTH,
Chris
04-07-2013 10:50 AM
UCM is Unified Communications Manager, IME is Inter-company Media Engine. Both server different purpose. CUCM is your IP-PBX and IME allows you to integrate 2 companies' CUCMs to essentailly allow free calling between the 2 companies bypassing PSTN.
HTH,
Chris
04-07-2013 10:51 AM
Hi Joy,
CUCM and IME are different components.For IME and Call Manager , u get two different PAKs installed on different servers.
IME is required for connecting different organisations through Internet rather than PSTN by configuraing SIP TRUNKS.
regds,
aman
04-07-2013 11:01 AM
I f we need only UCM pub and sub how many server required.
04-07-2013 11:04 AM
CUCM as of version 9 is no longer tracking nodes so you can install as many Subs as you want (obviously you have to follow clustering guidelines such as 8 call processors max, etc). Previous version such as 8.X node licenses were enforced but with CUWL licensee you get those for no charge, you just need to order the free node PAK.
HTH,
Chris
04-07-2013 11:12 AM
Please find below BOQ if we are using only CUCM how amny server required or server is include this BOQ
1 | CUCM-USR-LIC | Top Level Sku For User License | 1 |
2 | LIC-CUCM-USR-A | Unified Communications Manager Enhanced Single User-Under 1K | 50 |
3 | UCSS-UCM-1-1-A | UC Manager Enh UCSS Less than 1K users - 1 user - 1 year | 50 |
4 | LIC-CUCM-BASIC-A | Unified Communications Manager Basic Single User-Under 1K | 400 |
5 | UCSS-UCM-BAS-1-1-A | UC Manager Basic UCSS Less than 1K users - 1 user - 1 year | 400 |
6 | PUBLIC-IP-DEV-ADD | Pub.Space non-app phone add-on lobby, conf. room phones | 1 |
7 | UCSS-PUB-1-1 | UCSS for UCM Pub user for One Year - 1 user | 1 |
8 | UCM-7825-85 | CUCM 8.5 7825 | 2 |
9 | IME-7825-85 | IME 8.5 7825 | 2 |
10 | CCX-85-CMBUNDLE-K9 | CCX 8.5 Promo Bundle available only with NEW CUCM or BE6000 | 1 |
11 | CUCM-PAK | Include PAK Auto-expanding PAK for CUCM | 1 |
12 | CUCM-USR | Include PAK Auto-expanding User for CUCM | 1905 |
13 | IME-7825-85-KIT | IME 8.5 Media Kit | 1 |
14 | IME-7825-NODE | IME 7825 Node | 2 |
15 | IME-PAK | Include PAK Auto-expanding PAK for IME | 1 |
16 | UCM-7825-85-KIT | CUCM 8.5 Media Kit | 1 |
17 | UCM-7825-NODE | CUCM 7825 Node | 2 |
18 | UCSS-PUB-PAK | UCSS Public Space Devices Product Authorization Key | 1 |
19 | UCSS-UCM-BASIC-PAK | Include PAK Auto-expanding UCSS Basic PAK for CUCM | 1 |
UCSS-UCM-PAK | Include PAK Auto-expanding UCSS PAK for CUCM | 1 |
04-07-2013 02:10 PM
Hello
For CUCM MCS-7825 you can use two (one as publisher ) and other as subsriber . This is also based on customer needs and so on.
Thank you
please rate if this will help
04-07-2013 09:48 PM
So we have to order MCS server seperate right.
Thanks and regards
04-07-2013 11:13 PM
Hi Joy,
Please refer the Datasheet for IME which says
Cisco IME systems require three main components: a Cisco IME server, Cisco ASA 5500 Series Adaptive Security Appliances, and Cisco Unified CM 8.0 or Cisco Unified CM Session Management Edition 8.0.
regds,
aman
04-08-2013 05:20 AM
For this above BOQ how many MCS servers we have to order or servers already is there please avice me.
Thanks and regards
04-08-2013 05:57 AM
Is this for new install? If so, why would you go with version 8.5 and not 9.1? Also, why would you install MCS servers if they are going to be end of life in version 10 and no longer supported. You should be either looking at UCS servers or spec based from other vendors.
HTH,
Chris
04-08-2013 06:00 AM
Acually we has been ordered the licecnses long back as per customer recomendation so please guide us how many MCS servers rquired for the above BOQ.
Thanks in advance
04-08-2013 06:03 AM
Bill of Materials should be build based on system requirements, so whoever built it should have listed count for each item. Number of servers depends on your requirements, i.e. how many phones, users, are severs to be split between data centers, number of sites supported, etc. You need to go through the system sizing to determine optimal number of servers as this is not a wild guess.
Chris
04-08-2013 06:03 AM
HI
I would suggest you to open case at cisco.com/go/ph. It is free service to Cisco partners. PH team will be able to give you correct and authentic answer.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
04-08-2013 06:10 AM
Please find below list.in normal scnario we need IME node or not ?
UCM-7825-NODE Nos 2
IME-7825-NODE Nos 2
