UCM 8.5, Disable users ability to change PIN
travis-dennis_2
Level 7
Level 7
All,
Does anyone know of a way to disable a users ability to change their phone PIN from bot the phone and web access?
Thanks in advance!  All replies rated.
clileikis
Level 7
Level 7
Hi Travis,
You can disable the CCMUser page PIN option by going to:
System > Enterprise Parameters > Show Change PIN Option.
HTH,
Chris
