04-14-2008 01:22 PM - edited 03-15-2019 10:03 AM
I have a UCM6.1 running and I'm trying to add the first new subscriber. During the subscriber installation after I'm asked about the "first node" IP and other details, I get a error message: "this is not the first node". I am very sure about the IP address and Hostnames. Note:I'm not using DNS nor NTP. Note: Publisher can ping the new half-installed Subscriber. I've got 2 nodes licensing. What is happening? Is this a bug? Should I use DNS? Any help will be 5 point rated.
Solved! Go to Solution.
04-16-2008 07:45 AM
The security password is:
csc208@n2kcom
Any issue with the "@" ?
Maybe I need to change it and use only alphanumeric? Could I change the security pwd in the production Publisher?
Thanks all for your help.
04-16-2008 07:22 PM
Hi Carl,
The installation guide states -
"The password must contain at least six alphanumeric characters. It can contain hyphens and underscores, but it must start with an alphanumeric character"
You may try removing "@" character from the password.
I am not sure if it can be changed on the production publisher, hopefully the answer should be yes.
Can some throw some more light on this??
>> Sushil
04-16-2008 07:32 PM
Hi Carl,
Refer to one of the following procedures to reset the security password -
>> Sushil
04-17-2008 09:11 AM
Thank you Sushil, the issue was solved resetting the sec pwd. Five point for you.
04-17-2008 08:17 PM
Hi Carl,
Thats great. Can you please confirm if removing "@" resolved the issue or you used the same password again.
Enjoy.
>> Sushil
04-18-2008 10:00 AM
I have to use a new alphanumeric-only pwd.
Best regards.
