Resolved! cisco2801-ccme-k9 - DSP?
Hi, I've specced this up for a customer. I've also added a VWIC2-1MFT-T1/E1= . I dont need to order any DSP's do I? ie they should come as part of the bundle surley?
I have CME 4.2 12.4-11.XW6ATA ver. ATA030100SCCP040211A.zupGroup Pickup **4(group #)with Stationary ATA phone works O.K.Group Pickup **4(group #)with DECT ATA phone DOESNT work.Pickup **3(dn #)with Stationary ATA phone DOESNT work.Pickup **3(dn #)wit...
I use external call forward all. If the number I'm forward to is busy, is there a way to transfert the call back to Unity?
How can a user send a message to a group of 30 people using Unity Connection 2.0.1
looking for a way to transfer a call to another subscribers vm directly without ringing the phone. thanks for any help
I've had users indicate to me that MOH is not playing when they are during assisted/warm transfers, conference call initiation, etc. All users have dual-line DN'sSo, Basically, whenever you are putting an active call on "hold" (not actually using th...
Hi; I have a problem in integrating unity express (AIM) 2.3.1 installed in 3845 router with 12.4XY1 release, with CCM 5.0(4) server, what is the recommended gateway to be running between the CCM & the router? I tried SIP trunk with no use and H.323 ...
Hi,I have a phone connected to 2-port FXS card on ISR 2821 router.this router is registered to CCM 6.0.I selected SCCP while adding this voice router to the CCM.The problem is there is no dial-tone on the analogue phone connected to fxs port.Hence we...
HiI am having problems with a T1 circuit (ESF, B8ZS and E&M Winkstart) and CallManager 4.2.controller T1 1/0 framing esf linecode b8zs ds0-group 0 timeslots 1-24 type e&m-wink-start!This is terminating on a 2621XM with a NM-HDV.I can successfully mak...
I have a group of users who receive multiple hunt group calls from different external numbers. The external numbers are toll-free numbers which ring to local #'s that are DIDs on the PRI going into CUE 4.2. Each toll-free number is for a specific m...
The cluster in question is running CM5.1The normal operation cpu percentage is around 70-80% on the pub and 60-70 on the sub. There are approximately 450 phones registered.Is it normal to see this level of cpu usage?The process that seems to be hog...
Hi,I have CUCM 6.x and a MGCP gateway with SRST and several FXS ports with analog phones hanging off. I want the analog phones always registered to the SRST gateway rather than CUCM because in the event of a problem with CUCM, I do not want to wait ...
HI all,recently i tried to configure an ISDN connection with CallManager and it works fine but i'm stuck in something and thanks for ur previous posts by the wayI have a range of number from my SP like:from 555501 to 555509 and i want that a predefin...
With a T.37 off-ramp Gateway configuration, with a G3 fax at the receiving end; Is it possible to get status delivery notification when the fax has been delivered to the faxmachine? (In the documentation I only read about MDN messages when the receiv...
Has anyone got any recommendations for a USB handset that works (with hook/keyboard functionality) with Communicator?We have finally got our firewall configured for two way comms through VPN and would like to implement a number of users but all USB h...
Subject | Author | Posted |
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
