UCS TRCs
azhar.corvit
Newbei here
Is there any tool, metod or formula to calculate the required server configuration for UC Applications. For example, I have to run CUCM 8.5 and CCX 8.5 and Cisco Unity Connection on Cisco UCS, now how do I know which application is going to utilize what amount of resources and what should be the server configuration.
Thanks for help.
Azhar
Jonathan Schulenberg
Cisco has hidden all of this information on the DocWiki:
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization
Feel free to ask follow-up questions once you crawl through that. It can be a bit confusing at first so we're happy to provide additional guidence after you've RTFM.
Please remember to rate helpful responses and identify helpful or correct answers.
You can also use the Sizing Tools or call pre-sales for that
tools.cisco.com/cucst/faces/solutionsCatalog.jsp
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
