Udp profile line bulk update cucm 10.5
cloudconnected
Hello All,
Can anyone give any advice on how to perform bulk line update for over 4000 UDP profiles. Our environment is cucm 10.5.
We need to modify the max call and busy trigger  settings on all the UDP lines.
Can anyone provide any detailed step guide on how to achieve this?
Many thanks in advance.
You can do it From Builk Admin.
  • Go to Bulk Admin
  • Go to UDP updated Lines
  • click find or select your lines. Click next then select the busy trigger and Maximum number of calls. make sure that u check the box.
  • if you need to run this job immediately select the option mentioned below and click submit.
Response Signature
Nice break down of the steps @Nithin Eluvathingal (+5).
As this was so obvious and should be quite easy to find it begs the question if the OP even bothered to go into his/her system to check on this before asking for help.
Response Signature
Hello Nithin,
I have already tried these steps.
I wrote a detailed steps but looks like it has been removed from this form. I don't know why my reply was removed!
