Unable to add secondary DNS server
Gordon Ross
Level 9
Level 9
I'm running CUCM 8.6.2, and I'm unable to add a secondary DNS server to the CUCM in the CLI.
When I issue the command:
set network dns secondary X.X.X.X
I get the message back:
"     ***   W A R N I N G   ***
This will cause the system to temporarily lose network connectivity
Continue (y/n)?"
I reply "y" and I get the response (sometimes immediatly, other times after a delay)
"Executed command unsuccessfully"
Running packet captures I can't see any attempt to contact the DNS server. I can ping & ssh to the DNS server fine from the CUCM box.
What CUCM logs should I look via RTMT to try and diagnose this ?
GTG
Please rate all helpful posts.
Aaron Harrison
Not sure really - I've never seen it fail. I imagine you'll end up raising a TAC case for it as it will need root access etc.etc.
However... I would try:
file search activelog / 1.2.3.4 recurs reltime minutes 10 ignorecase
From the CLI, where 1.2.3.4 is the DNS server address you tried to add. That will scan all log files for occurences of that address, and hopefully show up where such changes are logged.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
5 Replies 5
Aaron Harrison
Aaron
Thanks for that. I think I've found the problem: A bug in CUCM.
If your primary DNS server IP address is, say, 192.168.1.10 and you then try to add 192.168.1.1 as a secondary, it complains that it already exists.
You can get round it by either:
a - Reversing the order of the DNS servers.
b - Putting a fake entry in for the primary. Set the secondary correctly. Then you can put the real entry in for the primary.
GTG
Do you have the bug ID for this issue ?
Godo news: Bug ID is CSCuf46934.
Bad news 1: Cisco won't fix the bug until at least CUCM 10.
Bad news 2: Cisco refuse to make this bug public. My SE can't find out why.
Thank you ,  Sir.
