unable to call a sccp ip phone with a sip ip phone
lguyomard
I'm experiencing an issue on ccme 8.6, I'm able to call a sip 7942 ip phone with a sccp 7942 ip phone but not the opposite, could anybody  help me, You'll be able to find in attachment  my configuration. The number of the SIP IP PHONE is 129.
Best regards,
7 Replies 7
odaijeriss
hi my friend,
could you please enable the following debugs:
debug voice ccapi inout
debug ccsip messages
do a testing call, and please attach the file.
Best Regards,
Odai Jeriss
You'll be able to fin in attachments the debug file log. Thanks for your help.
Best regards,
Ludovic GUYOMARD
hi my friend,
first of all thank you so much.
could you please confirm the following:
1- calling number
2- called number
3- where are both devices registered/
4- output from the following "show ip address trusted list"
Best Regards,
Odai Jeriss
Calling number is 129 (SIP IP PHONE) and called number is 130 (sccp IP PHONE)
Both devices are registered on the same cisco 2921 IP : 172.16.120.125
OUTPUT OF THE COMMAND :
PRS-CCME-01#Show ip address trusted list
IP Address Trusted Authentication
Administration State: UP
Operation State:      UP
IP Address Trusted Call Block Cause: call-reject (21)
VoIP Dial-peer IPv4 Session Targets:
Peer Tag        Oper State      Session Target
69              UP              ipv4:172.16.120.125
1234            UP              ipv4:172.22.97.20
8888            UP              ipv4:172.16.120.124
129             UP              ipv4:172.16.120.125
11              UP              ipv4:172.16.120.125
IP Address Trusted List:
Hi Ludovic,
The toll fraud feature is blocking your call.  Check out the following link for instructions on how to configure your CME using the new feature:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
HTH,
Chris
Chris,
if you read my previous reply this is what i am trying to confirm output from the following "show ip address trusted list". and asked about the places on which registered to provide Ludovic with the exact needed commands.
BR,
Odai
I've used this command to deactivate toll fraud but it's the same :
voice service voip
 no ip address trusted authenticate
Could it be an issue with a dial-peer as in the debug I've the following, I4ve sip:1@172.16.120.125;user=phone instead of sip:130@172.16.120.125;user=phone :
008411: Oct 27 15:59:42.554: //9517/22ABF09F8F8D/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
008412: Oct 27 15:59:42.554: //9517/22ABF09F8F8D/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
008413: Oct 27 15:59:42.554: //9517/22ABF09F8F8D/CCAPI/ccCallDisconnect:
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
008414: Oct 27 15:59:42.554: //9517/22ABF09F8F8D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 172.16.120.22:5060;branch=z9hG4bKb2cdd9ea
sip:129@172.16.120.125
>;tag=20370616dd270014c8a5711d-eb69c85c
To: <
>;tag=24DD8C64-1617
Date: Thu, 27 Oct 2011 14:59:42 GMT
Call-ID:
20370616-dd27000c-081936b7-f0a2bd2e@172.16.120.22
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=1
Content-Length: 0
Best regards,
Ludovic GUYOMARD
