Unable to configure E1 for R2 signalling
psnehas10
Hi ,
We got a new 4431 ISR router , base IOS //isr4400-universalk9.03.13.04.S.154-3.S4-ext.SPA.bin.
On which we have to configure R2 CAS signalling . Unfortunately I am not able to do that as it throws out and error when ever I mention type as r2-digital :(
R1(config)#controller e1 0/1/0
R1(config-controller)#ds0-group 0 timeslots 1-15,17-31
R1(config-controller)#$ timeslots 1-15,17-31 type r2-digital
ds0-group 0 timeslots 1-15,17-31 type r2-digital
% Invalid input detected at '^' marker.
If I search what is available for type I dnt see r2 signalling there
R1(config-controller)#$ timeslots 1-15,17-31 type ?
e&m-delay-dial E & M Delay Dial
e&m-immediate-start E & M Immediate Start
e&m-melcas-delay MEL CAS (CEPT) E & M Delay Start
e&m-melcas-immed MEL CAS (CEPT) E & M Immediate Start
e&m-melcas-wink MEL CAS (CEPT) E & M Wink Start
e&m-wink-start E & M Wink Start
fxo-ground-start FXO Ground Start
fxo-loop-start FXO Loop Start
fxo-melcas MEL CAS (Mercury) FXO
fxs-ground-start FXS Ground Start
fxs-loop-start FXS Loop Start
fxs-melcas MEL CAS (Mercury) FXS
Please need assistance on how I can configure this
Manish Gogna
Please configure as per the following
https://www-author.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/isr4400swcfg_chapter_010010.html#task_D69A71E834B641808CCDFA5443266E0B
Manish
soporte-vzla
Hi psnehas10 did you resolve the problem?. I am having the same issue.
