03-30-2015 07:07 PM - last edited on 03-25-2019 08:34 PM by ciscomoderator
I have configured the Voice Gateway and calls are working internally.
I recently installed a WIC-1B-S/T-V3 card to prepare to getting outside line access.
To try a set of Dial-Peer and put the port command , but I have been rejected.
I've confirmed that IOS Version,compatibility of WIC,PVDM is installed.
How do I get my WIC card to work?
The following is a show command.
【try set up】
R1#conf t
R1(config)#dial-peer voice 100 pots
R1(config-dial-peer)#port 0/0/0
% Invalid input detected at '^' marker.
R1(config-dial-peer)#port ?
<50-50> Voice interface slot #
R1(config-dial-peer)#port 50/?
<0-0> Voice interface SubUnit #
R1(config-dial-peer)#port 50/0/?
<1-20> Voice interface port # within vic
R1(config-dial-peer)#port 50/0/1
【show voice port summary】(i know 50/x/x voice port is automatically created.)
R1#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
50/0/1 1 efxs up up on-hook idle y
50/0/1 2 efxs up up on-hook idle y
-- omission --
50/0/20 1 efxs up up on-hook idle y
50/0/20 2 efxs up up on-hook idle y
【show ip interface brief】
R1#sh ip int brief
FastEthernet0/0 192.168.11.110 YES NVRAM up up
FastEthernet0/1 192.168.110.1 YES NVRAM up up
BRI0/0/0 unassigned YES NVRAM up up
BRI0/0/0:1 unassigned YES unset down down
BRI0/0/0:2 unassigned YES unset down down
Loopback0 1.1.1.1 YES NVRAM up up
【show diag】
R1#sh inve
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811 , VID: V01 , SN: FHK0934F0HR
NAME: "Wan Interface Card BRI S/T (3086)", DESCR: "Wan Interface Card BRI S/T (3086)"
PID: WIC-1B-S/T-V3 , VID: V01 , SN: FOC10515ZRK
NAME: "PVDMII DSP SIMM with one DSP", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16 , VID: V01 , SN: FOC104518AZ
R1#sh version
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(7), RELEASE SOFTWARE (fc6)
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-adventerprisek9-mz.124-7.bin"
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FHK0934F0HR
2 FastEthernet interfaces
1 ISDN Basic Rate interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Solved! Go to Solution.
03-30-2015 11:49 PM
the card which u are using supports Data .
you need to have VIC cards like VIC2-2BRI-NT/TE for Voice to work.
http://www.cisco.com/c/en/us/support/docs/voice/digital-ccs/7960-2isdn-bri-vic.html
regds,
aman
03-30-2015 10:14 PM
Hi Mate,
can you post the output of command:
sh voice dsp group all
-Terry
Please rate all helpful posts
03-30-2015 11:49 PM
regds,
aman
03-31-2015 12:58 AM
Aman is right here (+5) - its a data card and will not support voice.
-Terry
03-31-2015 02:36 AM
Thank you sooooooo much Aman and Terry.
You are right. I didn't notice at all.
regards
